A body clutch rod to pedal, bushing ?? #2407184
11/22/17 01:53 AM
11/22/17 01:53 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I’m doing my first 4 speed. The clutch rod ends have D shaped holes... when the clutch pedal has a round stud on it. What am I missing here? Is there a bushing that goes in the D ? Why make a D shaped hole that goes on a round stud? Thanks for any clarification.
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2407259
11/22/17 10:34 AM
11/22/17 10:34 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you are talking about the rod that goes through the firewall there is a stud on the pedal assembly and a stud on the "Z" bar, slip the ends over each stud and put a clip on them. shruggy
http://www.brewersperformance.com/proddetail.php?prod=CLC085
JB Rhinehart, Realist
A-Body's RULE!
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2407260
11/22/17 10:38 AM
11/22/17 10:38 AM
K
karengarneau Offline
K
There is no bushing just pressure from the spring that comes from the clutch fork to the bell housing keeps it in place. Small spring that is usually missing.
Re: A body clutch rod to pedal, bushing ?? [Re: Rhinodart] #2407274
11/22/17 11:28 AM
11/22/17 11:28 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Ok thanks. Just seems odd to put a round peg into a square hole. It works, thanks.
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2407393
11/22/17 03:35 PM
11/22/17 03:35 PM
K
K
sorry. after reading the question again I agree with rinodart. I was talking about the clutch adjustment rod which I believe is held in place with pressure only and the help of a small spring.
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2408276
11/24/17 03:21 PM
11/24/17 03:21 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I understand it just didn’t seem mechanically necessary to make an oval hole fit on a round peg.
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2408304
11/24/17 04:14 PM
11/24/17 04:14 PM
There should be two bushings on the clutch fork rod end, one is steel with a slot to fit over the clutch rod for alignment and a tapered lock nut for adjusting the clutch fork between it and the Z bar end of the cross shaft and the other is hard plastic bushing with a flat surface on the Z bar end and tapered to fit into the clutch fork and the steel washer bushing scope
IHTHs thumbs I use the Mopar A body kit due to it having the longest clutch rod up I'm not sure if they still sell it, I hope they do luck
If your talking about the shaft from the clutch pedal to the Z bar you need to keep in mind who assembled the cars back when whistling stirthepot grin
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2408321
11/24/17 05:05 PM
11/24/17 05:05 PM
USA
rftroy Offline
rftroy  Offline
USA
Here's a tip:
When you install the two clutch linkage rods, don't put any grease on the pins or the D of the rod. It needs to be bare steel on steel - per the Service Manual.
Due to its location, the clutch rods will pick up road dirt. The dirt will stick to the grease and will become an abrasive, actually causing the parts to wear quicker.
You will find this in Section 0, Lubrication, at the very end in the paragraph titled, "Parts Requiring No Lubrication".
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: A body clutch rod to pedal, bushing ?? [Re: rftroy] #2408435
11/24/17 10:59 PM
11/24/17 10:59 PM
The original Z bars had Teflon washers on them for the clutch pedal rods lubrication, not sure about the clutch pedal ends confused
Re: A body clutch rod to pedal, bushing ?? [Re: da50r] #2408554
11/25/17 03:57 AM
11/25/17 03:57 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
After a lot of miles that D shape gets wallowed out and bigger. Many moons ago I filled the extra space in the D with broken pieces of a small brass bushing. The washers held the pieces in. Worked good. Cost nothing.
I too always wondered why that piece was D shaped.
