Aluminum Hemi block no dipstick, drill? #2407138
11/22/17 12:26 AM
11/22/17 12:26 AM
Ohio
lockjaw-express Offline OP
Ohio
My Indy Aluminum Hemi block is not drilled for a dipstick. That said, is it possible to drill from underneath the engine after I remove the oil pan?
The engine is a 605 CI, and I am wondering if that is the reason for no dipstick?
I would like to drill from the bottom as the engine is already installed in the car.
Thank you for any suggestions, Mark
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407143
11/22/17 12:29 AM
11/22/17 12:29 AM
Washington
madscientist Offline
Washington
I don't run a dip stick.
If it doesn't leak, and it doesn't use oil what's the need?
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407146
11/22/17 12:34 AM
11/22/17 12:34 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Have a look at drilling and fitting a tube to the side of the pan
1963 Plymouth Max Wedge
1971 Barracuda
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407155
11/22/17 12:50 AM
11/22/17 12:50 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Get a sight glass.
Re: Aluminum Hemi block no dipstick, drill? [Re: rickraw] #2407158
11/22/17 12:57 AM
11/22/17 12:57 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Why do you need one?
Re: Aluminum Hemi block no dipstick, drill? [Re: GY3] #2407171
11/22/17 01:22 AM
11/22/17 01:22 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
As Rick said. Put a nice sight glass at the right level. Its not a bad idea to see if your oil looks like a milkshake from a water leak.
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407173
11/22/17 01:32 AM
11/22/17 01:32 AM
Ohio
Ohio
I would like to have a dip stick in the "original" place on the block...good way to check for any oil/water problems.
I have seen seepage from Pan mounted dip sticks, and the sight glass weeps oil as well. Both over time will start to leak, or seep oil.
With the long tube, the oil has less chance to leak or blow out.
Thanks, Mark
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407177
11/22/17 01:39 AM
11/22/17 01:39 AM
I would remove the oil pan and have a stock wedge steel dipstick tube welded into it up front and use it that way up scope twocents
Buy the same year dipstick at the same time and then calibrate it and mark it for your needs thumbs
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407186
11/22/17 01:56 AM
11/22/17 01:56 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If installed properly,a sight window leak is not common.They have sight glasses it carbs!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407228
11/22/17 06:16 AM
11/22/17 06:16 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I have done it from below, to a Megablock (iron) with a patched portion lacking the dipstick hole. I took measures from an old 440 block (any B/RB) and bored straight up till the hole was some .050"-0,1" deep, to steer the drill, then you sight and use the same angle as the cylinders/pistons (45 degrees). Be careful when the drill goes through on the backside. The hardest part is to get the new dipstick in from top, in a cramped engineroom. I used an openbox wrench around the dipstick flange and hammered it down, with RTV. Good luck!!
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407288
11/22/17 11:49 AM
11/22/17 11:49 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We put the dipstick tube to the side of the pan,there are kits available or just weld aluminium or steel block or round bar stock, drill and thread and use aftermarket thread on dipstick.Putting the tube in the stock location when using headers is a PITA.Do this below any windage tray to keep the dipstick away from the crank.
Re: Aluminum Hemi block no dipstick, drill? [Re: Hot 340] #2407403
11/22/17 03:56 PM
11/22/17 03:56 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Any suggestions on what site glass to use? I do have some ideas but was curious what others used.
Re: Aluminum Hemi block no dipstick, drill? [Re: markz528] #2407497
11/22/17 06:29 PM
11/22/17 06:29 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
look on msc industrial's web page. There's a ton. Heres an example.
Re: Aluminum Hemi block no dipstick, drill? [Re: B G Racing] #2407502
11/22/17 06:33 PM
11/22/17 06:33 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Truer words have never been spoken Bob. It took us HOURS on Barry's car.😂
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407509
11/22/17 06:53 PM
11/22/17 06:53 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never had one in a race motor. Street engine that gets miles put on it is a different situation.
A vac-u-pan system with clear hose tells you exactly whats going on in the engine moisture wise. Or in the puke tank if you're using a vacuum pump. Or pull a breather and look at it for milkshake. A problem will show up there before you see it on a dipstick.
Re: Aluminum Hemi block no dipstick, drill? [Re: lockjaw-express] #2407511
11/22/17 06:55 PM
11/22/17 06:55 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
When I was building HEMIs at Mopar Engines West I never put in dipsticks. Most guys are anal about changing their oil and if it’s not leaking or burning it, there’s no point. Nevertheless, I have had customers that demanded a dipstick rather than a blanky for emotional security. To me it’s a potential oil leak, a vacuum leak when running a vacuum pump, and snaking the dip stick around the headers is always fun. But yes, you can add it just by removing the pan a drilling a hole. I’d suggest making sure the new hole is dry and use “The Right Stuff” to hold the dipstick sleeve in the block.
