Re: Aluminum Hemi block no dipstick, drill?
[Re: lockjaw-express]
#2407143
11/22/17 12:29 AM
11/22/17 12:29 AM
Posts: 4,457 Washington
madscientist
Washington
I don't run a dip stick.
If it doesn't leak, and it doesn't use oil what's the need?
#2407146
11/22/17 12:34 AM
11/22/17 12:34 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Have a look at drilling and fitting a tube to the side of the pan
1963 Plymouth Max Wedge 1971 Barracuda
[Re: rickraw]
#2407158
11/22/17 12:57 AM
11/22/17 12:57 AM
Posts: 4,681 Wichita
GY3
Wichita
[Re: Hot 340]
#2407403
11/22/17 03:56 PM
11/22/17 03:56 PM
Posts: 4,272 Morrow, OH
markz528
Morrow, OH
As Rick said. Put a nice sight glass at the right level. Its not a bad idea to see if your oil looks like a milkshake from a water leak. Any suggestions on what site glass to use? I do have some ideas but was curious what others used.
[Re: B G Racing]
#2407502
11/22/17 06:33 PM
11/22/17 06:33 PM
Posts: 3,395 Pa
Hot 340
Pa
Putting the tube in the stock location when using headers is a PITA. Truer words have never been spoken Bob. It took us HOURS on Barry's car.😂
#2407509
11/22/17 06:53 PM
11/22/17 06:53 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never had one in a race motor. Street engine that gets miles put on it is a different situation.
A vac-u-pan system with clear hose tells you exactly whats going on in the engine moisture wise. Or in the puke tank if you're using a vacuum pump. Or pull a breather and look at it for milkshake. A problem will show up there before you see it on a dipstick.
