Re: Looking for some help from Prestolite Distributor gurus
[Re: dragon slayer]
#2400469
11/08/17 01:36 PM
11/08/17 01:36 PM
RapidRobert
I don't have any info but I would try Googling.
[Re: dragon slayer]
#2400629
11/08/17 06:36 PM
11/08/17 06:36 PM
RapidRobert
I read it but I did not think it thru. Sorry! (I'll do better next time).
[Re: dragon slayer]
#2403983
11/15/17 02:57 PM
11/15/17 02:57 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Thank you. I guess the 68 and 69 IBS series for big block 4014 for the hemi.
I have some loose cams with markings such as:
A L; AA IBP RG; B LU; and Y LV (which I have seen on the 1970 340 4 Barrel 4 speed DP distributor)
I also have a bearing plate.
Also if there is any info on the tach drive Hemi versions that Mopar performance had for the A body hemi cars. Here is an original,also they came with Platinum contacts.
