Page 1 of 3 1 2 3
Broke my K Frame #2405773
11/19/17 02:02 AM
11/19/17 02:02 AM
California
mickm Offline OP
mickm  Offline OP
California
So the perch that the engine mount bolts to on the K Frame is completely broken on the passenger side. It has slid about an inch and a half away from it's original position, and it's pretty obvious to see the engine leaning way to the left.
Think this is possible to repair in the car? Lift the engine as far out of the way as possible, weld this thing back on?
Doesn't seem feasible to me, although a friend suggested it.
Pretty bummed out about this at the moment, but I guess as hard as I drive this car, it isn't unexpected.
If I have to take it out, is it reasonable to just hoist the engine out of the way, or do I really need to pull the engine and trans?
Re: Broke my K Frame [Re: mickm] #2405783
11/19/17 02:33 AM
11/19/17 02:33 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Support the engine and pull the k-member out. I have done many k-member repairs, but haven't encountered this issue before. I don't see where it would be that difficult, though. A bare block with the mounts attached should work to get it back. It might also be obvious where it goes...
Re: Broke my K Frame [Re: mickm] #2405788
11/19/17 02:42 AM
11/19/17 02:42 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Is it a clean break or has it chewed up the crack some? Can you get it clean enough and prepped in the car to weld in the car? Any issues getting the mig torch head in there and will it be a difficult weld in terms of the position? If it is possible to weld in the car I'd remove any ignition boxes, and voltage regulators or other electronics in the car lest the weld current damage them. I fried a voltage regulator on a mower welding up a part with a mig welder.
Re: Broke my K Frame [Re: mickm] #2405796
11/19/17 03:14 AM
11/19/17 03:14 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I would say pull it, and send to Mega Parts, I think they have a jig, and then it would be done right. They
Re: Broke my K Frame [Re: mickm] #2405801
11/19/17 03:44 AM
11/19/17 03:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Or send it to Firm Feel. While there, they can weld in their reinforcement bracing kit.
Is this the 383 K member or a genuine HEMI K member?
Re: Broke my K Frame [Re: Kern Dog] #2405821
11/19/17 05:15 AM
11/19/17 05:15 AM
California
mickm Offline OP
mickm  Offline OP
California
I haven't had a good view of exactly what it looks like yet. It is the 383 K Member, not the hemi one. I think once I have it out it will be very obvious how it all goes back together, I just can't imagine doing a proper job of it while it is still in the car.
I just have to come up with a good way to support the engine, and then the rest is just dropping it out.
Re: Broke my K Frame [Re: mickm] #2405825
11/19/17 06:36 AM
11/19/17 06:36 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
That is not a hard to find K member. All 318 and 383 cars used it from 70-72. I am told the 440 cars had that unique skid plate but was otherwise identical.
Re: Broke my K Frame [Re: mickm] #2405826
11/19/17 06:37 AM
11/19/17 06:37 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Like this one.
Re: Broke my K Frame [Re: mickm] #2405854
11/19/17 10:46 AM
11/19/17 10:46 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I supported my engine and pulled the K-Member to repair and reinforce at the steering box mounts when I broke a steering box. Made it much easier to repair it, and there was no guessing if I had repaired all the cracks. Included a pic with the k-member out. By the way this was with a low deck, 440-1 heads and the original pro parts headers. Have since gone to a custom set of headers.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Broke my K Frame [Re: mickm] #2405908
11/19/17 01:51 PM
11/19/17 01:51 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The 70 unit is unique as it has the sway bar through the k but the steering box angle is the same as the earlier years. 71-2 the box angle changed and to use it you need the center link from those two years too then you should be ok. 71 on is the same as the e-bodies from what I've found out. Found this out when putting a 70 unit in my 65 Coronet.
Carl Kessel
Re: Broke my K Frame [Re: mickm] #2405914
11/19/17 02:01 PM
11/19/17 02:01 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Late 69 would have the same indents in the k-frame for the 70 sway bar, just no holes drilled which would be easy to do. I have a 71 k-frame in my 69 belevedere... has no issues with it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Broke my K Frame [Re: mickm] #2406008
11/19/17 06:11 PM
11/19/17 06:11 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Find another k frame, if the mount is broken, what else?
Re: Broke my K Frame [Re: cudaman1969] #2406015
11/19/17 06:22 PM
11/19/17 06:22 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Take a good look at your transmission tailshaft while your are under there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Broke my K Frame [Re: pittsburghracer] #2406016
11/19/17 06:28 PM
11/19/17 06:28 PM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
I agree with Pittsburghracer.....check your tail shaft while you're under there....great advice!
HR20
Re: Broke my K Frame [Re: HotRod20] #2406034
11/19/17 07:43 PM
11/19/17 07:43 PM
California
mickm Offline OP
mickm  Offline OP
California
HR20
Ugh..!
Will do...
Re: Broke my K Frame [Re: mickm] #2406118
11/19/17 11:04 PM
11/19/17 11:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Good idea: I would expect the left mount to want to pull up, not so much the right one. I wouldn't worry about a new K-member, welding this one shouldn't take more than 30 minutes and you have to pull it out anyway.
Sheldon
Re: Broke my K Frame [Re: RUNCHARGER] #2406137
11/19/17 11:34 PM
11/19/17 11:34 PM
California
mickm Offline OP
mickm  Offline OP
California
Yea, my plan is to weld it, and just reinforce all the other welds.
Re: Broke my K Frame [Re: mickm] #2406185
11/20/17 01:57 AM
11/20/17 01:57 AM
None
71rm23 Offline
71rm23  Offline
None
If it can be welded, fine. If needing another K, get a hold of Moparmarks member here. Either way, I'd consider a torque strap for the final install as well.
Re: Broke my K Frame [Re: mickm] #2406227
11/20/17 06:05 AM
11/20/17 06:05 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
When you pull the kframe, take it to a machine shop and have it hot tanked, less things to burn when welding. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Broke my K Frame [Re: mickm] #2406529
11/20/17 09:57 PM
11/20/17 09:57 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
That is a great idea. I should do that next time.
Page 1 of 3 1 2 3
