Odd change in MPH #2405385
11/18/17 11:54 AM
11/18/17 11:54 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I took my 12 year old baby Benz to the Texas Motorplex for some street car night runs with a few coworkers. This was my first passes on a track in at least 8 years and I've own this car less than 2 months.
I only managed to get three runs in due to the heavy crowds and a lengthy down time from a pair of Mustangs racing each other into the gravel trap. realcrazy
The first run had the lengthy cool down. The second and third runs had the engine at normal run temps and 20+ mph wind gusts blowing from about the 2:00 position when on the track.
On each run I had the traction control off, the shifter in drive (with sport mode) and rolled the throttle in quickly but not too harshly.
The runs were:
60' . . 1.984 . . 2.024 . . 2.040
330 . . 5.603 . . 5.699 . . 5.728
1/8 . . 8.582 . . 8.695 . . 8.735
mph . . 81.73 . . 83.67 . . 83.30
1000. . 11.132. . 11.288. . 11.814
E.T.. . 13.288. . 13.448. . 13.512
mph . . 104.19. . 104.75. . 104.19
I don't think I was spinning the mismatched tires (bought it with a Pirelli PZero and Michelin Pilot Sport A/S3 out back). I couldn't feel them spin and there was no chance of hearing it. Looking at the short times I'm pretty sure the little 245/45-18s were hooking up.
What would be the most likely explanation for picking up 2 mph in the 1/9 mile but running the same mph in the 1/4?
In the end, I'll take those passes. They're right in line with what I expected out of the car.
- Stu Harmon
Re: Odd change in MPH [Re: feets] #2405468
11/18/17 03:14 PM
11/18/17 03:14 PM
Wind velocity change in the 1/8 mile shruggy
Where do the spectator stands end work
Re: Odd change in MPH [Re: Cab_Burge] #2405645
11/18/17 09:03 PM
11/18/17 09:03 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The more comfortable you got the rougher you got.. and she don't like it rough
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Odd change in MPH [Re: feets] #2405871
11/19/17 11:56 AM
11/19/17 11:56 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the north side stands (wind was from the north) completely block the wind until the 600 ft mark.
Joe
Without Data, you’re just another guy with an opinion.
Re: Odd change in MPH [Re: sr4440] #2405877
11/19/17 12:03 PM
11/19/17 12:03 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Optimal for that mph is a 1.77 60 ft. and 12.74 e.t.
Not bad for a street tire, though.
'63 Dodge 330
11.19 @ 121 mph
Re: Odd change in MPH [Re: feets] #2405910
11/19/17 01:52 PM
11/19/17 01:52 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't know accurate their lights are either. Look at the difference in time between the 1000ft and 1/4 on the third run compared to the first two runs. Something is wrong with the numbers.
[image][/image]
Re: Odd change in MPH [Re: sgcuda] #2405925
11/19/17 02:31 PM
11/19/17 02:31 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
If that's the case it's a shame it wasn't a more entertaining error like the one from east Texas years ago. It had me at 384 mph in the 1/8. smile
- Stu Harmon
Re: Odd change in MPH [Re: sgcuda] #2406009
11/19/17 06:11 PM
11/19/17 06:11 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the 11.814 makes no sense, a 11.334 would make sense. I suspect a typo or sensor issue.
Joe
Re: Odd change in MPH [Re: sr4440] #2406038
11/19/17 07:51 PM
11/19/17 07:51 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Joe
I went back and looked at the slip again. No typo.
You should see my reaction time from that pass. It was nearing midnight and they slipped in a pro tree. I saw all three lights hit and thought "huh, they used a pro tree" then it hit me. I SHOULD BE GOING NOW!
Yeah, not pretty. : laugh2
- Stu Harmon
