511 low deck head upgrade! #2405340
11/18/17 06:17 AM
11/18/17 06:17 AM
junction city oregon
V
viperblue72 Offline OP
V
With so many choices out there I am not sure what direction to go on new heads. My combo
Low deck 511
12:1ish compression
Right now I have a 274@050 solid lifter with 590 lift and 108. That may change to a roller.
I don’t necessarily want to maximize the combo but I want the best bang for the buck within reason. My thoughts are ez-1, trick flow 270, or a victor max wedge. I’m not afraid to try some of my own porting.
Car is 2800lbs valiant
727 haven’t chose converter
8 3/4 with 4.56 temporarily
31x13.5 slick.
I see the trick flows are down a bit on flow from ported ez or ported victors.
But would they give up a lot to those in horsepower?
Re: 511 low deck head upgrade! [Re: viperblue72] #2405341
11/18/17 06:17 AM
11/18/17 06:17 AM
V
V
Also I do plan to add 1.6 rockers if I keep this cam.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405396
11/18/17 12:34 PM
11/18/17 12:34 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I had a stock stroke 440 with heads being ported more Cam than you but car weighed about the same as yours it went 10.10 @ 132 with Indy ez-1
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 511 low deck head upgrade! [Re: viperblue72] #2405433
11/18/17 01:54 PM
11/18/17 01:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In the long run, TF 270's will likely be the least expensive, and they come CNC ported.
I doubt there would be much power difference between the 3 with any flat tappet cam similar to what you have now.
If it were my own, it would get EZ-1's.
The initial cost is less, they use less expensive rockers, and with fairly basic porting will flow 350+.
I haven't had a TF 270 on my bench yet, but if they are as close to the published specs as the 240's are, they should flow in the 345cfm range.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405462
11/18/17 03:07 PM
11/18/17 03:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
MCH CNC ported 440-1 up
The 2.250 intake valve upgrade is worth doing also scope
Why not start with a goods set of heads to start with work up twocents
I have a set of Eddy CNC ported M.W. Victor on my bracket car, I'm not impress with them and the results compare to other motors I've race with that had the CNC ported MCH 440-1 shruggy
Re: 511 low deck head upgrade! [Re: Cab_Burge] #2405475
11/18/17 03:23 PM
11/18/17 03:23 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have the victor max wedge on my 511 cnc ported flow 359@.600-.800 on a conservetive bench. Still tuning and really cant say til i hit the track but not overly impressed yet. I would do the 440-1 if i had to do it over right now.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405594
11/18/17 07:42 PM
11/18/17 07:42 PM
V
V
What does a ez-1 head flow with just a basic clean up?
Re: 511 low deck head upgrade! [Re: viperblue72] #2405614
11/18/17 07:59 PM
11/18/17 07:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
In the "best of moparts" section, there is an Indy head info thread with a bunch of flow numbers.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405672
11/18/17 10:04 PM
11/18/17 10:04 PM
V
V
The search engine is over my head apparently. I can’t find it.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405678
11/18/17 10:10 PM
11/18/17 10:10 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Re: 511 low deck head upgrade! [Re: viperblue72] #2405719
11/18/17 11:59 PM
11/18/17 11:59 PM
V
V
Perfect thanks. That’s really great info Dwayne. I appreciate you sharing. Your bench must also be tough. I really love the idea of going straight to the dash one. But the price doubles at the least and that’s before more expensive rockers.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405739
11/19/17 12:39 AM
11/19/17 12:39 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The victors take a pricey rocker as well. I went HS@1100 a set.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405745
11/19/17 12:49 AM
11/19/17 12:49 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Track only?
Performance goals?
Re: 511 low deck head upgrade! [Re: viperblue72] #2405795
11/19/17 03:12 AM
11/19/17 03:12 AM
AndyF Offline
AndyF  Offline
There is a set of -1 heads with Jesel 1.60 rocker arms for sale in the race section. That is a good price for a proven combo of parts. You can make a lot of power with -1 heads and Jesel rocker arms and those parts should last a long time on a bracket type of engine. If you sell your existing heads and rocker arms then you'll be able to offset a lot of cost.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405812
11/19/17 04:18 AM
11/19/17 04:18 AM
V
V
It is a mostly strip car and very limited street. I don’t have an exact goal other than I want to make the most power with the best head for the dollar. And I plan to get the car down to 2600.
I imagine deep 9s are likely eventually. I did build the short block to handle more than I have.
Billet caps, scat rods with the good bolts, Mahle pistons.
I’ll check out the dash -1 heads in the race section. And I did sell my heads today. I am really leaning toward the trick flow 270. And maybe run them as is. Later on port on them a bit more.
Re: 511 low deck head upgrade! [Re: AndyF] #2405831
11/19/17 06:53 AM
11/19/17 06:53 AM
V
V
I sent him a pm thank you. Anyone need a brand new trick flow low deck 4150 intake?
Re: 511 low deck head upgrade! [Re: viperblue72] #2405859
11/19/17 11:07 AM
11/19/17 11:07 AM
gregsdart Offline
gregsdart  Offline
For a budget friendly motor that will hit bottom nines high eights at 2600, personally for a motor that will be relatively low maintanance I would consider the following; Indy ez-1 heads (large port) with the best porting (could wait on porting) and 2.25 valve size NOW if you buy them new. Use a cam with an endurance type lobe so you don't have to spend a fortune on valvetrain.
If you buy used heads with Jesel rockers, dissasemble the intake rockers far enough to look at the needle bearing cages. If abused with a real radical cam, a magnifying glass will let you see if any of the needle bearing cages have cracked, or the snap rings are worn thin. Also spin the rockers on the shafts all the way around to check for bind, which is a failed bearing. Keep a close eye on lash, and if you see a change of .003, start looking till you find what failed. Something did,trust me!
You could buy spares for the Jesel system,(very expensive) or buy just a left and right mini shafts. You can buy the needle bearings and snap rings locally and make a bearing tool out of bolts and the right sized bronze bushings to disasemble them and rebuild them, just measure where the bearings are supposed to be.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405869
11/19/17 11:49 AM
11/19/17 11:49 AM
V
V
Thank you for the advice. I hope to find out more about these -1. It might be a good idea to use ez-1 and just port them later as money allows. I really need to work on the rest of the car and make it safe first. It’s basically an 11 sec. car with a 9 sec motor now.
Re: 511 low deck head upgrade! [Re: viperblue72] #2405915
11/19/17 02:04 PM
11/19/17 02:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
Those used -1's are showing "sold"?
The pic of the included manifold with that combo looks like a 440-3x, which is really too big for the OP's combo.
Still a good price though.
Re: 511 low deck head upgrade! [Re: fast68plymouth] #2405917
11/19/17 02:16 PM
11/19/17 02:16 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
A good price...those were the head with unknown chamber volume.
I'm personally holding out for a set that has a little documentation. Buying ported heads with no history, flow sheets or other data is a big gamble.
