Removing motor with K member #2405279
11/18/17 01:48 AM
11/18/17 01:48 AM
Kalamazoo, MI
StrokedW7 Offline OP
Kalamazoo, MI
How many people remove the motor with the K frame from the bottom? I'm getting my car painted and I'm just curious if that might be a good way to keep from scratching the car when I get it back.
Thanks in advance for any input.
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Removing motor with K member [Re: StrokedW7] #2405294
11/18/17 02:12 AM
11/18/17 02:12 AM
TX
O
OSDart Offline
OSDart  Offline
O
TX
That is the preferred method. If you own or have access to a lift(two post) the removal is very easy.
Re: Removing motor with K member [Re: StrokedW7] #2405296
11/18/17 02:14 AM
11/18/17 02:14 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do it once, and you will never want to do it any other way.
Re: Removing motor with K member [Re: StrokedW7] #2405338
11/18/17 05:43 AM
11/18/17 05:43 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Make and use these for the rear wheels and use jack stands for the front. Drop the engine from the bottom the safe way.
https://www.youtube.com/watch?v=8HHQqGnU5DQ
Re: Removing motor with K member [Re: StrokedW7] #2405342
11/18/17 07:09 AM
11/18/17 07:09 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Uhhhh...How do you get the engine out from the bottom if the front wheels are on the car??? The wheels and suspension are attached to the K member, sir....
Re: Removing motor with K member [Re: 71birdJ68] #2405343
11/18/17 07:19 AM
11/18/17 07:19 AM
None
71rm23 Offline
71rm23  Offline
None
Agree!!!!
Re: Removing motor with K member [Re: OSDart] #2405366
11/18/17 10:54 AM
11/18/17 10:54 AM
Kalamazoo, MI
Kalamazoo, MI
I have a two post lift and being i have an Alterkation front end seems like it would be pretty easy.
A couple of dumb questions... What do you set the motor and transmission on? I know I've seen something with wheels that bolts to the front of the car that allows you to still move the car around. Where is the best place to buy something like that? Any other tips, tricks or suggestions would be appreciated.
Re: Removing motor with K member [Re: StrokedW7] #2405368
11/18/17 11:03 AM
11/18/17 11:03 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You need to make a dolly that rest is the rear hole of the k frame and tail shaft of the tranny. I’ve got one. Only way to fly.
Re: Removing motor with K member [Re: StrokedW7] #2405369
11/18/17 11:13 AM
11/18/17 11:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Done it many times. Like said, you have to make a dolly to rest the k-frame and trans tail shaft on. I just used 2x4's and some casters. I never had access to a lift I did mine by lifting the car and putting the nose on jackstands.
Re: Removing motor with K member [Re: StrokedW7] #2405478
11/18/17 03:28 PM
11/18/17 03:28 PM
Los Osos, Ca
CKessel Online content
CKessel  Online Content
Los Osos, Ca
I made up a dolly for mine that takes the engine and trans. Have been slipping it in and out for test fits into my car. I have a 4 post lift. If you shoot me a pm with your e-mail, I'll send you some photos. Doing photos here, for me, is too convoluted a process.
Carl Kessel
Re: Removing motor with K member [Re: CKessel] #2405504
11/18/17 04:32 PM
11/18/17 04:32 PM
Kalamazoo, MI
Kalamazoo, MI
I see us car tools makes a dolly and some body castles.
Re: Removing motor with K member [Re: StrokedW7] #2405507
11/18/17 04:34 PM
11/18/17 04:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Why spend that kind of money, just go to harbor freight and get one of the furniture dollies for the motor/trans and use that.
Re: Removing motor with K member [Re: 71birdJ68] #2405725
11/19/17 12:04 AM
11/19/17 12:04 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if you remove it from the bottom does it require a complete front end alignment?
Re: Removing motor with K member [Re: bonefish] #2405734
11/19/17 12:27 AM
11/19/17 12:27 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Maybe not, all that is disconnected is the spindle from the upper ball joint. But, I would still have it checked.
Re: Removing motor with K member [Re: Kern Dog] #2405823
11/19/17 05:48 AM
11/19/17 05:48 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Good point Greg, hey, it was late! grin
Re: Removing motor with K member [Re: StrokedW7] #2405824
11/19/17 06:35 AM
11/19/17 06:35 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Woooo!
Sir "Posts A Lot" makes a boo boo ?
Re: Removing motor with K member [Re: StrokedW7] #2406132
11/19/17 11:20 PM
11/19/17 11:20 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
Some Harbor Fright tire dollys and 3/4" plywood will support the drive train (this is a 383). Be careful where you support the car to not bend the unibody.
Re: Removing motor with K member [Re: StrokedW7] #2406366
11/20/17 03:40 PM
11/20/17 03:40 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Funny, on the ride into work this AM, I was thinking about how I am going to do this, Was my plan and should be doing in the next couple of months. And the thought that came to mind was how my engine lift legs would probably interfere with the engine rolling under.
Looks like the US Car Tool idea gives you more distance. Allows you to put the legs on the lift all the way out and not have to extend the boom, making it much safer.
http://store.uscartool.com/uni-lift-unibody-front-end-lifting-tool.html
Re: Removing motor with K member [Re: StrokedW7] #2406485
11/20/17 07:38 PM
11/20/17 07:38 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
here is the roller assembly I made for my satellite . . .made the plate big enough to rotate 90 deg, so I could then bolt it in place with the legs sticking out front to lift the car with the engine hoist . . . engine/tranny and k member on a car wheel dolly thing . . .
