Flaming River Steering Coupler #2405158
11/17/17 08:15 PM
11/17/17 08:15 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
What's the proper way to bolt in the coupler at the splined end? The one I just purchased has a set screw with lock nut on one side and a bolt with 1/2 threads and a smooth section and on other end which need to go through the steering shaft with a roll pin?
I've seen a video where it says dimple the set screw into the shaft but I don't want to mess up the splines on the steering box.
Re: Flaming River Steering Coupler [Re: Sammy] #2405238
11/17/17 11:56 PM
11/17/17 11:56 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Does the set screw end up on the void on the steering box input shaft?
Re: Flaming River Steering Coupler [Re: Sammy] #2405240
11/18/17 12:07 AM
11/18/17 12:07 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Spline has a set screw and the roll pin goes through the shaft.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Flaming River Steering Coupler [Re: hemi-itis] #2405304
11/18/17 02:40 AM
11/18/17 02:40 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
How far into the coupling does the steering shaft go ? Thanks Gary
Re: Flaming River Steering Coupler [Re: Sammy] #2405305
11/18/17 02:44 AM
11/18/17 02:44 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You need to drill the column shaft. Did you buy this used or something? They come with pretty good instructions. Maybe there is a copy of them at their website.
Re: Flaming River Steering Coupler [Re: Sammy] #2405322
11/18/17 04:00 AM
11/18/17 04:00 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The steering box should have a cut out area in the middle of the spline where the bolt would slide through. The bolt holds the joint from sliding off when tightened down. Set screw? never seen one on the same end . The roll pin as you say goes through the other end . If you have a hollow steering shaft the shaft should have a plug welded into the end, then drilled and pinned. A thin hollow steering shaft will cause the pin to shear leaving you with no steering. Double d joints have set screws, Is this what you have?
Re: Flaming River Steering Coupler [Re: Sammy] #2405428
11/18/17 01:42 PM
11/18/17 01:42 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
This is a new unused coupler in a sealed plastic bag. Reading the directions makes no reference to the strange looking bolt with nut that is threaded about half way.
This bolt is supposed to go through the coupler into the splines and it would gall the splines once penetrated through the other end.
I get the part about drilling through the shaft but doing anything to the spline area is confusing.
Re: Flaming River Steering Coupler [Re: Sammy] #2405632
11/18/17 08:35 PM
11/18/17 08:35 PM
hemi-itis Offline
hemi-itis  Offline
I think the set screw goes to the flat spot on the splines,,,,,,,I think work
Re: Flaming River Steering Coupler [Re: hemi-itis] #2405661
11/18/17 09:34 PM
11/18/17 09:34 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
There is no flat spot on my splines. Set screw will go right into the splines and theres another long bolt that will hit the splines and go through the other side with a nut.
Re: Flaming River Steering Coupler [Re: Sammy] #2405715
11/18/17 11:41 PM
11/18/17 11:41 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have a flaming river colume in my 67 A body. They are a GM colume with Gm wiring. They told me simple plug and play. They lied. Had to cut my original colume plug and hard wire. Their diagram did not match what i had. No real help when i called.
Re: Flaming River Steering Coupler [Re: Sammy] #2405832
11/19/17 07:00 AM
11/19/17 07:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my 63 I went from power to manual steering. So all I had to do was add in this adapter to take up the room that the larger P/S box used. Its nice when thats all I am doing. Good luck with yours. Ron
Re: Flaming River Steering Coupler [Re: Sammy] #2406330
11/20/17 02:21 PM
11/20/17 02:21 PM
cleveland, ohio
AJsDUSTER Offline
AJsDUSTER  Offline
cleveland, ohio
I have a Flaming river coupler. The splined side that goes to the steering box has one set screw that is tightened were the roll pin used to go. So you are not tightening the set screw down on any splines.
