Re: Flaming River Steering Coupler
[Re: hemi-itis]
#2405304
11/18/17 02:40 AM
11/18/17 02:40 AM
Posts: 342 Indiana
Gabby63
Indiana
How far into the coupling does the steering shaft go ? Thanks Gary
[Re: Sammy]
#2405322
11/18/17 04:00 AM
11/18/17 04:00 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
The steering box should have a cut out area in the middle of the spline where the bolt would slide through. The bolt holds the joint from sliding off when tightened down. Set screw? never seen one on the same end . The roll pin as you say goes through the other end . If you have a hollow steering shaft the shaft should have a plug welded into the end, then drilled and pinned. A thin hollow steering shaft will cause the pin to shear leaving you with no steering. Double d joints have set screws, Is this what you have?
[Re: Sammy]
#2405632
11/18/17 08:35 PM
11/18/17 08:35 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I think the set screw goes to the flat spot on the splines,,,,,,,I think
[Re: hemi-itis]
#2405661
11/18/17 09:34 PM
11/18/17 09:34 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I think the set screw goes to the flat spot on the splines,,,,,,,I think There is no flat spot on my splines. Set screw will go right into the splines and theres another long bolt that will hit the splines and go through the other side with a nut.
