Water pump housing milling
#240382
03/01/09 09:31 PM
03/01/09 09:31 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
What is the most I can mill a BB water pump housing? My elephant ears are 3/8" and I don't want to use a 3/8" crank pulley spacer because I don't have a lot of room to play with. Can I take the whole 3/8" off the housing, or would I be safer taking 1/4" and using a 1/8" spacer on the crank? Thanks guys! Here's a picture of what I'm working with:
Re: Water pump housing milling
[Re: mopowers]
#240386
03/01/09 09:49 PM
03/01/09 09:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats another possibility Mike. The car will see a lot of street time though, so I'm not too sure I want to put all my trust into an electric pump. I was just curious what the max was for milling a pump housing.
There is tons of hot rods running electric water pumps on the street, the CSR or Meziere style pumps with electric fans on the rad
[Re: mopowers]
#240388
03/01/09 09:56 PM
03/01/09 09:56 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
I am not sure what the max is but years ago we milled one down so everything would line up and I had continuous leaking problems. Found out that as it was milled down, the water pump holes became larger and didn't line up with the gaskets I was using on the waterpump to motor plate. Just something to keep in mind.
[Re: RonP]
#240390
03/01/09 10:17 PM
03/01/09 10:17 PM
Posts: 2,567 Appalachia
RedRam
Appalachia
My plate is 3/8", milled the alum mopar housing the same amount. That made the gasket surface a little thin in a couple of spots. Used a spool gun to add a little metal and re-milled the high spots. All is good. I also had to clearance the rear of the thermostat area of the housing and the plate a little.
