Water pump housing milling #240382
03/01/09 09:31 PM
03/01/09 09:31 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What is the most I can mill a BB water pump housing? My elephant ears are 3/8" and I don't want to use a 3/8" crank pulley spacer because I don't have a lot of room to play with.
Can I take the whole 3/8" off the housing, or would I be safer taking 1/4" and using a 1/8" spacer on the crank?
Thanks guys!
Here's a picture of what I'm working with:
Re: Water pump housing milling [Re: mopowers] #240383
03/01/09 09:34 PM
03/01/09 09:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a electric pump on it, then you wont have to mill
Re: Water pump housing milling [Re: MR_P_BODY] #240384
03/01/09 09:39 PM
03/01/09 09:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
or a electric water pump drive like the Moroso or Mr Gasket ones I milled my first water pump housing a 1/4 inch, which was the same thickness as my elephant ears
Re: Water pump housing milling [Re: MR_P_BODY] #240385
03/01/09 09:41 PM
03/01/09 09:41 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thats another possibility Mike. The car will see a lot of street time though, so I'm not too sure I want to put all my trust into an electric pump. I was just curious what the max was for milling a pump housing.
Re: Water pump housing milling [Re: mopowers] #240386
03/01/09 09:49 PM
03/01/09 09:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is tons of hot rods running electric water pumps
on the street, the CSR or Meziere style pumps with
electric fans on the rad
Re: Water pump housing milling [Re: MR_P_BODY] #240387
03/01/09 09:54 PM
03/01/09 09:54 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
My ears are also 3/8" and i had our machine shop mill mine and i have had no problems at all.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Water pump housing milling [Re: mopowers] #240388
03/01/09 09:56 PM
03/01/09 09:56 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I am not sure what the max is but years ago we milled one down so everything would line up and I had continuous leaking problems. Found out that as it was milled down, the water pump holes became larger and didn't line up with the gaskets I was using on the waterpump to motor plate. Just something to keep in mind.
Re: Water pump housing milling [Re: MR_P_BODY] #240389
03/01/09 10:04 PM
03/01/09 10:04 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Milling more than 1/4" on my stock housing would have opened up one of the water port walls so it was to thin to seal. I then used a 1/4" motor plate with no problem. Using an electric pump will work on the street also. Call up a few manufacture's for their recommendations.
Re: Water pump housing milling [Re: RonP] #240390
03/01/09 10:17 PM
03/01/09 10:17 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
My plate is 3/8", milled the alum mopar housing the same amount.
That made the gasket surface a little thin in a couple of spots. Used a spool gun to add a little metal and re-milled the high spots. All is good.
I also had to clearance the rear of the thermostat area of the housing and the plate a little.
Re: Water pump housing milling [Re: mopowers] #240391
03/01/09 10:41 PM
03/01/09 10:41 PM
AndyF Offline
AndyF  Offline
I've made the suggestion a few times to the water pump mfgs that they make a race housing. It would come milled down already and it wouldn't be drilled for the heater hose fittings. So far nobody has bothered to introduce this as a product but I still think it is a good idea.
Re: Water pump housing milling [Re: AndyF] #240392
03/02/09 12:42 AM
03/02/09 12:42 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm thinking of getting the 440 source aluminum pump housing. Has anyone milled one of these 1/4" or 3/8" and not had problems with it sealing?
Does anyone know how much thinner the electric pumps are vs the mechanical ones?
Re: Water pump housing milling [Re: mopowers] #240393
03/05/09 12:40 PM
03/05/09 12:40 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Has anyone milled their 440source aluminum water pump housings? Is there enough meat to take 1/4" off and not have sealing issues?
