Need measurements-69 Charger console brackets #2402543
11/12/17 03:03 PM
11/12/17 03:03 PM
NH
N
NHCharger Offline OP
N
NH
I am swapping my Charger from column shift to console. I picked up a used console and brackets at Carlisle.
If someone has a project car and could give me some measurements for the three brackets that would be up
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: Need measurements-69 Charger console brackets [Re: NHCharger] #2403270
11/13/17 10:45 PM
11/13/17 10:45 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Nobody chimed in, so I'll give it a try. I installed a console on my non console RR, basically things will lay were they want to. Put the brackets on the console and with trial and error move the console around till it feels, and looks right, then mark where the brackets go.
Re: Need measurements-69 Charger console brackets [Re: 71birdJ68] #2403342
11/14/17 12:57 AM
11/14/17 12:57 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
I measured my 69. The first bracket is 4 3/16 from the seam. The second bracket is 19 1/8 from the seam. Both are to the left of the tunnel center.
Re: Need measurements-69 Charger console brackets [Re: 58pwrwgn] #2403652
11/14/17 07:43 PM
11/14/17 07:43 PM
NH
N
N
NH
Thanks for the info.
