Manual Trans Guys....Check this out! #2402530
11/12/17 02:52 PM
11/12/17 02:52 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Re: Manual Trans Guys....Check this out! [Re: Dragula] #2402704
11/12/17 08:39 PM
11/12/17 08:39 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
$2400 and still uses the clutch confused
Re: Manual Trans Guys....Check this out! [Re: Dragula] #2402709
11/12/17 09:00 PM
11/12/17 09:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Ugly. Clunky. And kinda pointless.
Re: Manual Trans Guys....Check this out! [Re: Pacnorthcuda] #2402752
11/12/17 10:15 PM
11/12/17 10:15 PM
Dragula Offline OP
Dragula  Offline OP
Well, my guess is they will improve it more over time. And it might be a tad large, but I have never liked H-pattern shifters. The Mopars are some of the worst I have driven. Think of how many missed shifts will be avoided with one of these...
With todays clutches, hydraulic throw out bearings and crazy fluid flow adjusters you can buy as well as the electronics, having a clutch is becoming less and less of an issue.
Did you catch the part about pressure sensitive handle so you don;t need the clutch? Seems a few places make more stuff I haven't even seen yet.
Re: Manual Trans Guys....Check this out! [Re: Dragula] #2402841
11/13/17 12:41 AM
11/13/17 12:41 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Price isn't bad for what it is but the part is massive and quite hard to look at....however, in a racecar, it's not much of a deterrent. There isn't much need for a sequential on a "street car", to me.
Offering a gear counter would be nice. My ECU will give me a calculated gear indicator, but a non-EFI car wouldn't give that feedback. It's not vital, but nice to have.
If I was in the market, I'd like to know what their plan is for not needing a clutch before I trashed a set of syncros. I am not sure how a shifter assembly could overcome that, even with a shift cut input to an ECU.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Manual Trans Guys....Check this out! [Re: Dragula] #2403029
11/13/17 02:37 PM
11/13/17 02:37 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Crude set-up to what's been in Class 8 Trucks for over 20 years now.
I might have missed it if they offer it, but it needs to be run with Drive-By-Wire to work precisely. Otherwise, you gotta be awful good with the skinny pedal (yeah, no matter how great you think you are at rev-matching a computer is better).
Get behind the wheel of an Eaton Auto-Shift before you Guys make judgment on this idea. twocents Drivers laughed at these when they came out; now almost every truck on the road is Autoshift.
Mo' Farts
Moderated by "tbagger".
Re: Manual Trans Guys....Check this out! [Re: Grizzly] #2403132
11/13/17 05:45 PM
11/13/17 05:45 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The Eaton is nice for a tractor but is nothing really worth mentioning in a race application. They are still quite slow, but obviously have a significant amount of inertia to deal with. We have a very large portion of our build as AMTs
2020 RAM 1500
Re: Manual Trans Guys....Check this out! [Re: Dragula] #2403273
11/13/17 10:56 PM
11/13/17 10:56 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yeah, I guess Ferrari, BMW, Mercedes, Volvo, and Eaton are all doing wrong, huh? rolleyes
So, this is what replaces the stick on top of the transmission in an 18 speed, it's called and "x y shifter". You take off with the clutch and this little box does all the shifting for you in milliseconds. No gear grinding at all, it always gets it right.
Mo' Farts
Re: Manual Trans Guys....Check this out! [Re: GoodysGotaCuda] #2403287
11/13/17 11:27 PM
11/13/17 11:27 PM
Goody; automatic transmissions (as in Allisons) or Autoshift? On the KW side about 85-90 percent is still manual (and not Autoshift) and about 10-15 percent Allisons.
Re: Manual Trans Guys....Check this out! [Re: Dragula] #2403314
11/14/17 12:14 AM
11/14/17 12:14 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
AMT is an Automated Manual Transmission, there Mother-Trucker. tonguue
This sequential thing isn't new, bikes have had this since the beginning of time.
Mo' Farts
Re: Manual Trans Guys....Check this out! [Re: Grizzly] #2403325
11/14/17 12:34 AM
11/14/17 12:34 AM
Yes, but they are still the minority. Most manuals are still standard. They may becoming the "it shifter" but I don't think it's quite there yet.
What do I know, I only watched about 100,000 being built over the last 17 years.
Re: Manual Trans Guys....Check this out! [Re: Pacnorthcuda] #2403330
11/14/17 12:40 AM
11/14/17 12:40 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The Allisons are not all that popular for us, naturally they find their way into smaller trucks or vocational applications. We are heavily pushing the AMTs [especially the "PACCAR AMT") along with the column mounted shifter since we do see better fuel economy by removing some of the driver input. I'd have to take a gander and the build mix, but there is a steady decrease in linehaul manuals.
2020 RAM 1500
