Affordable wideband o2 kits #2402345
11/12/17 02:37 AM
11/12/17 02:37 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
What are some good working affordable wideband o2 kits?
I’m trying to find something simple with a sensor and exhaust bung and gauge for around 100-200 bucks.
I’ve got a quickfuel super street 680 vacuum secondary carb and I need to get a wideband on it to take full advantage of the adjustability on it.
I have it tuned by feel and by reading spark plugs right now but I know I’m leaving some power and mileage on the table by not having a wideband in it.
I’ve found a few on eBay for 150-200 that include everything, I’m just hoping they accurate and work good.
Here is one of them
https://www.ebay.com/itm/GRAMS-DIGITAL-W...2-/141420377938
Re: Affordable wideband o2 kits [Re: pjc360] #2402355
11/12/17 02:49 AM
11/12/17 02:49 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Innovate lc2 may meet your criteria. Should be about $175 shipped
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Affordable wideband o2 kits [Re: GoodysGotaCuda] #2402377
11/12/17 04:42 AM
11/12/17 04:42 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
I see this one on eBay, but I don’t see a gauge anywhere in the kit to observe the a/f ratio....
https://www.ebay.com/itm/Innovate-3796-L...o-/152619300787
Re: Affordable wideband o2 kits [Re: pjc360] #2402392
11/12/17 10:19 AM
11/12/17 10:19 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Vague ad but the gauge comes in that white box. Search the part number on innovates site, it’ll have a gauge.
2020 RAM 1500
Re: Affordable wideband o2 kits [Re: pjc360] #2402394
11/12/17 10:25 AM
11/12/17 10:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have 2 LC2's that I have been real happy with. I found the best pricing was on eBay as well.
68 Barracuda Formula S 340
Re: Affordable wideband o2 kits [Re: pjc360] #2402444
11/12/17 12:51 PM
11/12/17 12:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Logging abilities are very important. Having just a guage is okay for something steady like looking at the cruise A/F, but then a narrow band could suffice for that if that is all you need.
But if you want to look at the A/F during acceleration, things change very fast and very often. Logging and graphing is the only way to see what is happening and to evaluate the impact of your adjustments.
Master, again and still
Re: Affordable wideband o2 kits [Re: pjc360] #2402446
11/12/17 12:59 PM
11/12/17 12:59 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Actually, not as much as you may think. The AFR gage is useful in helping observe the effects of various changes. If you want one, great. But you can do pretty darn good without.
A dash gage alone will be most useful for steady conditions; Wide open throttle in top gears, steady on the highway at lower and higher speeds.
The adjustments in your QF are probably the air bleeds and what else? The airbleeds most effect the shape of the fuel curve. With the AFR gage, tach and video, that can be observed in top gears in the 1/4 mile. So for this, a gage or logger can speed things along. Best mph is still going to be the indicator of best power at the top of the run.
For milage - on the interstates, the limit will be when the engine starts surging. AFR gage, rpm, vac are only helpful in telling you what conditions the limit was hit.
Re: Affordable wideband o2 kits [Re: pjc360] #2402767
11/12/17 10:46 PM
11/12/17 10:46 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
I have the Innovate LC-2
It hasn't done me a bit of good.
Been setting on the shelf for 2 years and never installed. But installation is actually in my plans for the next week or two.
Re: Affordable wideband o2 kits [Re: Mattax] #2402771
11/12/17 10:55 PM
11/12/17 10:55 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
dumb question, do you need a bung for each header?
Re: Affordable wideband o2 kits [Re: pjc360] #2402774
11/12/17 10:57 PM
11/12/17 10:57 PM
AndyF Offline
AndyF  Offline
Here is one of them
I have an AEM kit that I never installed. I can't swear that it is complete anymore since the box is gone but the gauge, O2 sensor and wiring harness are there. Shoot me a PM and I'll sell it to you for cheap.
Re: Affordable wideband o2 kits [Re: jcastle1] #2402779
11/12/17 11:09 PM
11/12/17 11:09 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If you want to, sure, but it's not critical unless you have a major issue somewhere. If you're just tuning on a known good setup, one is fine. Having two can help you identify an issue by comparing the two.
2020 RAM 1500
Re: Affordable wideband o2 kits [Re: pjc360] #2403346
11/14/17 01:06 AM
11/14/17 01:06 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
For folks with the LC-2, what made you go with the LC-2 instead of the MTX-L?
Re: Affordable wideband o2 kits [Re: mopowers] #2403351
11/14/17 01:16 AM
11/14/17 01:16 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I wanted it to standalone, I don't really need the gauge that comes with it.
Second gauge from the right is AFR and the other LC2 output goes directly to my EFI controller.
2020 RAM 1500
Re: Affordable wideband o2 kits [Re: pjc360] #2403922
11/15/17 12:33 PM
11/15/17 12:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bought in innovate lc-1 and gauge 10 years ago. A great investment and in your price range.
