Originally Posted By jcastle1
dumb question, do you need a bung for each header?
If you want to, sure, but it's not critical unless you have a major issue somewhere. If you're just tuning on a known good setup, one is fine. Having two can help you identify an issue by comparing the two.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
