SNAP! #240090
03/01/09 04:50 PM
03/01/09 04:50 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
semi finals. 2 cars away from staging. engine stumbles, gave her a blip on the pedal. dead! push it away, check no spark. found dizzy not spinning. pulled dizzy & drive out, all ok, wind over enging, cam not rotating but cambelt is.
damn, broken roller cam. 1 1/2 seasons old. anyone have similar problems with Comp Cams breaking. mines only a tame unit, spring pressure is only 500 on the nose but it broke just past the first journal, now i need to find a similar replacement & a few valves. don't you hate motorsport when this sort of nonsence happens?
Re: SNAP! [Re: rebel] #240091
03/01/09 05:20 PM
03/01/09 05:20 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Had the same thing happen but with a flat tappet cam. Are you running a timing chain? Mine was loose and that is what I was told was the cause. The chain going from loose to tight to loose and the cam basicilly getting whipped back an forth.
Re: SNAP! [Re: atoetly] #240092
03/01/09 05:26 PM
03/01/09 05:26 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
no chain. it's a dry belt with idler so no flexing of the belt. belt is still firm.
Re: SNAP! [Re: rebel] #240093
03/01/09 05:35 PM
03/01/09 05:35 PM
Chicagoland
chargerron69 Offline
Chicagoland
i had the pin that holds the cam to the gear break before. every thing spins but the cam
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: SNAP! [Re: chargerron69] #240094
03/01/09 08:50 PM
03/01/09 08:50 PM
Only on single bolt cams, I have seen more than one Isky single bolt cam have the pin come out and end up in the oil pan It tears up a lot of valves if theere close to the minimum V to P clearances
