Re: leaf spring front segment
[Re: sam64]
#2400398
11/08/17 11:54 AM
11/08/17 11:54 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Longer. Use the chevy length spring.
[Re: sam64]
#2400463
11/08/17 01:29 PM
11/08/17 01:29 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
I can't remember the exact front segment length but I'm pretty sure the spring for an S-10 pickup has the longest segment. There isn't one "Chevy" length. It depends on the model.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: sam64]
#2400466
11/08/17 01:32 PM
11/08/17 01:32 PM
an8sec70cuda
Pretty sure the length everyone uses is 25". Stock Mopars are either 20" or 22" IIRC. If you talk to Calvert Racing about the monoleaf springs, they'll tell you.
[Re: sam64]
#2400514
11/08/17 02:51 PM
11/08/17 02:51 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Dont forget 21 also The early models had it.My 65 B runs a 21 inch but now has 20 inch SS springs with the correct hangers.Rocky
Chrysler Firepower
[Re: sam64]
#2400539
11/08/17 03:37 PM
11/08/17 03:37 PM
Posts: 625 Indianapolis In. usa
Quickrunner
I went with the chevy front segment length, its 25 inches. Calvert will help you on the phone with spring selection.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: sam64]
#2400932
11/09/17 12:18 PM
11/09/17 12:18 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
So if you run a longer front segment do you have to compensate by moving the front spring hanger forward?
71 440-6 4spd & 69 Hemi 4spd
[Re: hemi_doug]
#2400942
11/09/17 12:40 PM
11/09/17 12:40 PM
Quickrunner
So if you run a longer front segment do you have to compensate by moving the front spring hanger forward? Yes, by how ever longer you go with the segment. To keep the axel in same location.
[Re: sam64]
#2401081
11/09/17 06:10 PM
11/09/17 06:10 PM
Quickrunner
$$$ good shocks is my guess. On really really fast car anyway. Like custom Mencer or Santhuff.
[Re: a493demon]
#2401221
11/10/17 01:16 AM
11/10/17 01:16 AM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
cals. took some time but with help from Demon gup over the phone we got it working . Good to know. Thanks.
[Re: a493demon]
#2401230
11/10/17 01:27 AM
11/10/17 01:27 AM
Posts: 4,676 Wichita
GY3
Wichita
I did have menscer do the shocks on mine . The DA afco's were at the limit . Was it the extension part you had to work on firming up?
[Re: a493demon]
#2401233
11/10/17 01:29 AM
11/10/17 01:29 AM
GY3
Wichita
Can you give some details on your setup?
[Re: Quickrunner]
#2401293
11/10/17 08:26 AM
11/10/17 08:26 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Guys, I'm really confused with this possibility to change front spring segment lenght.
My concern is about front hangers, I'm using relocation spring kit and can't see how I can move hangers forward as you can see in this example attached.
Pictures will be great!
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
