Page 1 of 2 1 2 >
#2400395 - 11/08/17 08:50 AM leaf spring front segment
sam64 Offline
Loc: okla.
I am thinking about putting cal-tracs on my belvedere,should I stay with 20" front seg.or go longer?Springs are already moved into the frame so fabbing for longer springs is not an issue.Thanks,Sam.
10.86@123
#2400398 - 11/08/17 08:54 AM Re: leaf spring front segment [Re: sam64]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Longer. Use the chevy length spring.
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
#2400463 - 11/08/17 10:29 AM Re: leaf spring front segment [Re: sam64]
Runnoft Offline
Loc: VA Beach, VA
I can't remember the exact front segment length but I'm pretty sure the spring for an S-10 pickup has the longest segment. There isn't one "Chevy" length. It depends on the model.
66 Dodge Coronet 500
Indy SR 440
Gen 7 Accel DFI
3977 lbs = 11.38 @ 116
#2400466 - 11/08/17 10:32 AM Re: leaf spring front segment [Re: sam64]
Pretty sure the length everyone uses is 25". Stock Mopars are either 20" or 22" IIRC. If you talk to Calvert Racing about the monoleaf springs, they'll tell you.
CHIP
#2400514 - 11/08/17 11:51 AM Re: leaf spring front segment [Re: sam64]
therocks Offline
Its Lost
Loc: Niles , Ohio
Dont forget 21 also The early models had it.My 65 B runs a 21 inch but now has 20 inch SS springs with the correct hangers.Rocky
Chrysler Firepower
#2400539 - 11/08/17 12:37 PM Re: leaf spring front segment [Re: sam64]
Quickrunner Offline
Loc: Indianapolis In. usa
I went with the chevy front segment length, its 25 inches. Calvert will help you on the phone with spring selection.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
2004 Jeep Liberty
09 Challenger R/T 6spd
Missin' my 9 second 70 runner!
#2400651 - 11/08/17 04:35 PM Re: leaf spring front segment [Re: sam64]
a493demon Offline
Loc: baldwinsville new york
Digby runs the 20inch still and his cars been 4.19 in the 1/8th.
I run the 20 also and have been 5.46 so far .
#2400932 - 11/09/17 09:18 AM Re: leaf spring front segment [Re: sam64]
hemi_doug Offline
Loc: Northern N.J.
So if you run a longer front segment do you have to compensate by moving the front spring hanger forward?
71 440-6 4spd & 69 Hemi 4spd
#2400942 - 11/09/17 09:40 AM Re: leaf spring front segment [Re: hemi_doug]
Quickrunner Offline
Yes, by how ever longer you go with the segment. To keep the axel in same location.
2004 Jeep Liberty
#2401024 - 11/09/17 12:48 PM Re: leaf spring front segment [Re: a493demon]
humpty Offline
Loc: Minnesota, USA
Ok I’ll bite. What is the secret to making the 20” spring work?
72 Duster - 408ci W2, 10.18@131, 6.31@110.
https://m.youtube.com/watch?v=Q4P51j38-MI
#2401081 - 11/09/17 03:10 PM Re: leaf spring front segment [Re: sam64]
Quickrunner Offline
$$$ good shocks is my guess. On really really fast car anyway. Like custom Mencer or Santhuff.
2004 Jeep Liberty
#2401125 - 11/09/17 05:25 PM Re: leaf spring front segment [Re: Quickrunner]
humpty Offline
Loc: Minnesota, USA
I still think the longer segment is the way to go but after talking with Menscer's tech they've convinced me they can make the 20" work. I even gave them the option of the longer spring and they said it's not needed. Since I already own the shocks its just the cost of the valving. I'm looking at the same money to relocate and (re)buy the parts for the springs.
I still plan on mounting the shocks straight up, and maybe move them to the front of the axle.
For the OP - I'd still go with the longer springs. I haven't heard anyone report regretting doing so.
#2401128 - 11/09/17 05:31 PM Re: leaf spring front segment [Re: sam64]
a493demon Offline
I did have menscer do the shocks on mine .
The DA afco's were at the limit .
#2401131 - 11/09/17 05:41 PM Re: leaf spring front segment [Re: a493demon]
humpty Offline
Loc: Minnesota, USA
Got it. Are you using the CalTrac bars, Assassin bars or something else?
#2401137 - 11/09/17 06:14 PM Re: leaf spring front segment [Re: sam64]
a493demon Offline
cals. took some time but with help from Demon gup over the phone we got it working .
#2401221 - 11/09/17 10:16 PM Re: leaf spring front segment [Re: a493demon]
humpty Offline
Loc: Minnesota, USA
Good to know. Thanks.
#2401230 - 11/09/17 10:27 PM Re: leaf spring front segment [Re: a493demon]
GY3 Offline
Loc: Wichita
Was it the extension part you had to work on firming up?
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's
10.69 @ 128mph with 150hp shot of nitrous
#2401233 - 11/09/17 10:29 PM Re: leaf spring front segment [Re: a493demon]
GY3 Offline
Loc: Wichita
Can you give some details on your setup?
'63 Dodge 330
11.19 @ 121 mph
#2401238 - 11/09/17 10:38 PM Re: leaf spring front segment [Re: sam64]
a493demon Offline
They changed both settings.
When the car was in the 10's the afco DAs worked good .
Now that it's in the 8s it just over powered the afcos the way they were valved.
71 Demon 540 on nitrous stock front and rear suspension mini tubed springs moved in 3 inches 28x10.5 tire .4.10 gears cope 2nd gear leave trans brake valve body .
#2401293 - 11/10/17 05:26 AM Re: leaf spring front segment [Re: Quickrunner]
360tripleblack77 Offline
Loc: Gravataí, RS, Brazil
Guys, I'm really confused with this possibility to change front spring segment lenght.
My concern is about front hangers, I'm using relocation spring kit and can't see how I can move hangers forward as you can see in this example attached.
Pictures will be great!
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Page 1 of 2 1 2 >
25,639 Registered Members
195,761 Topics
1968 Dodge Charger 383 V8 Automatic
by tomsjack
12/19/18 02:42 AM
Why are people still upset about the 4 door Charger?
by DUFFMAN
12/18/18 09:46 PM
Starter issue with JW Ultrabell
by Sammy
12/18/18 09:27 PM
Later 440's have sodium filled valves??
by Prodart440
12/18/18 08:22 PM
