Re: Best source of damper pulley - OEM style
[Re: varunner]
#2400095
11/07/17 07:04 PM
11/07/17 07:04 PM
Posts: 661 Virginia
varunner
Virginia
Balancer is p/n 917470E with a stock crank. I plan on putting the alternator pulley where ever it needs to go. Race only engine.
[Re: varunner]
#2401551
11/10/17 08:08 PM
11/10/17 08:08 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Andy your motor plate and alternator mount setup has been on my with list for a long time. Needs to be done as I run a 16v system and charge between rounds. Several times this year they called us up before I was charged. It makes it hard on the system especially running fans and water pump between rounds in hot TX weather.
I am also looking at pulleys for my ATI 917122E Super Damper and 16v alternators that will work with your brackets.
Guess I need to sit down and put together a list of parts because it is one of the upgrades I plan on doing over the winter. This thread reminded me to add it to my list of To-Do stuff LOL.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: AndyF]
#2403047
11/13/17 03:16 PM
11/13/17 03:16 PM
Posts: 661 Virginia
varunner
Virginia
If is race only then use the shallow pulley from DMI. yes, stock eliminator. Do you have a link for DMI ? thanks
