Best source of damper pulley - OEM style #2399925
11/07/17 01:33 PM
11/07/17 01:33 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Looking for a simple 1-groove pulley to fit an ATI balancer.
Re: Best source of damper pulley - OEM style [Re: varunner] #2399943
11/07/17 02:10 PM
11/07/17 02:10 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Mancini
Re: Best source of damper pulley - OEM style [Re: varunner] #2400011
11/07/17 04:32 PM
11/07/17 04:32 PM
AndyF Offline
AndyF  Offline
Depends on which ATI balancer you have. ATI makes about 20 different balancers and the pulley face is not in the stock location on most of them.
Re: Best source of damper pulley - OEM style [Re: varunner] #2400095
11/07/17 07:04 PM
11/07/17 07:04 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Balancer is p/n 917470E with a stock crank. I plan on putting the alternator pulley where ever it needs to go. Race only engine.
Re: Best source of damper pulley - OEM style [Re: qwkmopardan] #2400778
11/08/17 11:59 PM
11/08/17 11:59 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
thanks, 440 source has a couple too.
Re: Best source of damper pulley - OEM style [Re: varunner] #2400781
11/09/17 12:06 AM
11/09/17 12:06 AM
AndyF Offline
AndyF  Offline
If is race only then use the shallow pulley from DMI.
Re: Best source of damper pulley - OEM style [Re: varunner] #2401551
11/10/17 08:08 PM
11/10/17 08:08 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Andy your motor plate and alternator mount setup has been on my with list for a long time. Needs to be done as I run a 16v system and charge between rounds. Several times this year they called us up before I was charged. It makes it hard on the system especially running fans and water pump between rounds in hot TX weather.
I am also looking at pulleys for my ATI 917122E Super Damper and 16v alternators that will work with your brackets.
Guess I need to sit down and put together a list of parts because it is one of the upgrades I plan on doing over the winter. This thread reminded me to add it to my list of To-Do stuff LOL.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Best source of damper pulley - OEM style [Re: varunner] #2401564
11/10/17 08:28 PM
11/10/17 08:28 PM
AndyF Offline
AndyF  Offline
For a race setup I use the shallow pulley from Doty. You can make anything fit if you spend enough time on it, but the Doty stuff is really nice and doesn't take up much space so that is what I start with.
Re: Best source of damper pulley - OEM style [Re: AndyF] #2403047
11/13/17 03:16 PM
11/13/17 03:16 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
yes, stock eliminator. Do you have a link for DMI ? thanks
