Big Block - valley pan vs valley plate #2399495
11/06/17 06:27 PM
11/06/17 06:27 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Whats the pros/cons to running a valley plate vs the old valley pan?
Re: Big Block - valley pan vs valley plate [Re: DusterKid] #2399536
11/06/17 07:36 PM
11/06/17 07:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
First question: What cylinder heads?
Re: Big Block - valley pan vs valley plate [Re: DusterKid] #2399569
11/06/17 08:18 PM
11/06/17 08:18 PM
AndyF Offline
AndyF  Offline
For the average person you want to run what you need to run. That is, standard type heads should use a valley pan while extended runner heads should use a valley plate.
Re: Big Block - valley pan vs valley plate [Re: DusterKid] #2399853
11/07/17 10:23 AM
11/07/17 10:23 AM
Keymar, MD
Keymar, MD
Currently have 440 stealths, but have TrickFlow 240s on the list for Santa...
Re: Big Block - valley pan vs valley plate [Re: DusterKid] #2399924
11/07/17 01:32 PM
11/07/17 01:32 PM
AndyF Offline
AndyF  Offline
Those are standard port heads so they work best with a valley pan. I designed a solid valley with batwing gasket holders for the TF 240 heads so I could get the port match perfect. It isn't really needed for a normal engine but I was trying to make as much power as possible.
Re: Big Block - valley pan vs valley plate [Re: DusterKid] #2400080
11/07/17 06:47 PM
11/07/17 06:47 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have cnc stealth heads , port is bigger than pan and felpro gasket . currently I use the tray etc opened up by hand . But it still pulls a little oil into #1 port , got the others sealed up second time round. I have a set of Andy's batwings and some Superformance gaskets on the way , I will use these with my home made valley plate . Hope this will stop all oil pull through
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Big Block - valley pan vs valley plate [Re: tex013] #2400105
11/07/17 07:22 PM
11/07/17 07:22 PM
AndyF Offline
AndyF  Offline
Yep, that is a common problem. I designed my batwing gasket holders just for the CNC ported head issue.
Re: Big Block - valley pan vs valley plate [Re: AndyF] #2400242
11/07/17 11:45 PM
11/07/17 11:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
look forward to using them Andy
Tex
New best MPH 130.32
Re: Big Block - valley pan vs valley plate [Re: tex013] #2400245
11/07/17 11:49 PM
11/07/17 11:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Tex
You won't be dissapointed, they work well.
