Re: Big Block - valley pan vs valley plate
[Re: DusterKid]
#2399569
11/06/17 08:18 PM
11/06/17 08:18 PM
Posts: 30,945 Oregon
AndyF
Whats the pros/cons to running a valley plate vs the old valley pan? For the average person you want to run what you need to run. That is, standard type heads should use a valley pan while extended runner heads should use a valley plate.
[Re: DusterKid]
#2400080
11/07/17 06:47 PM
11/07/17 06:47 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
I have cnc stealth heads , port is bigger than pan and felpro gasket . currently I use the tray etc opened up by hand . But it still pulls a little oil into #1 port , got the others sealed up second time round. I have a set of Andy's batwings and some Superformance gaskets on the way , I will use these with my home made valley plate . Hope this will stop all oil pull through
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2400105
11/07/17 07:22 PM
11/07/17 07:22 PM
AndyF
Yep, that is a common problem. I designed my batwing gasket holders just for the CNC ported head issue.
[Re: AndyF]
#2400242
11/07/17 11:45 PM
11/07/17 11:45 PM
tex013
Sydney,Australia
Yep, that is a common problem. I designed my batwing gasket holders just for the CNC ported head issue. look forward to using them Andy Tex
[Re: tex013]
#2400245
11/07/17 11:49 PM
11/07/17 11:49 PM
dartman366
Mt. Vernon, Ohio
Yep, that is a common problem. I designed my batwing gasket holders just for the CNC ported head issue. look forward to using them Andy Tex You won't be dissapointed, they work well.
