Re: First outing with junkyard 5.7 = Win!!
[Re: moparmitch]
#2398603
11/04/17 11:44 PM
11/04/17 11:44 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Thanks everyone for the positive comments. The headers are botched to say the least. They are actually cheapo pacesetter 1 3/4 headers for ram pickup with early port heads. So port alignment is not even close for the eagles. Reworked a couple tubes on each side to make them fit. A good set of headers would probably make a noticeable improvement. We don't run any accessories or alternator. Used a truck timing cover and rigged a moroso pump drive to the factory water pump. The mounts are a combination of Schumacher BB perches and street and performance engine mounts.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2398722
11/05/17 11:06 AM
11/05/17 11:06 AM
71yelladustr
Missouri U.S.A.
I'd be surprised if A body headers will fit. The passenger side upper control arm Is very close to the head. The frame also angles inward directly behind the engine with the rear lower control arm mount also taking up valuable space. It's just tight.
[Re: 71yelladustr]
#2445218
02/02/18 03:17 PM
02/02/18 03:17 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
when I mocked up an actual eagle head and early short block and standard head gasket it came out to around 11.5 compression. With the fast burn chambers, double quench pads, EFI, dual spark plugs, plastic intake... I would bet you would be totally fine on premium pump fuel. The only problem you might run into is if your tuner gets too agressive with the timing, these things really don't need much. Heck the apache is 10.9 and you know the factory is going to be very conservative on compression for emmisions reasons (NOX specifically). I think a low buget early 5.7 short block with a 6.1 cam and eagle heads/intake would be a buget motor to be reckoned with.
[Re: 71yelladustr]
#2469706
03/21/18 02:20 PM
03/21/18 02:20 PM
Posts: 1,552 Michigan
Kiddart
I keep hearing that guys are finding these JY gems for $900 to $1500 bucks. what JY and Where. around me they are like gold
Thank you Kiddart
[Re: Kiddart]
#2469757
03/21/18 03:34 PM
03/21/18 03:34 PM
Posts: 2,045 MD
RTSE4ME
MD
[Re: 71yelladustr]
#2469802
03/21/18 04:55 PM
03/21/18 04:55 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
They seem to go fast when they are cheap. I have a couple extras, so I don't even look for more now because I don't need more junk Last one I bought was a '12 with 34k but block was broke. Paid less than heads are worth. Plus got a perfect rotating assembly, lifters, rockers, etc. 09 and up are cheaper it seems than the earlier ones. Guess it's a supply/demand thing.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 71yelladustr]
#2471969
03/25/18 08:48 PM
03/25/18 08:48 PM
71yelladustr
Missouri U.S.A.
The cheap stuff is usually broken or blowed up. The engine we used in the build was a core. The customer had overheated it and popped the head gaskets. I didn’t want to put headgaskets on it and risk it dropping a valve seat. So we put a set of eagles and fresh gaskets on it and rolled on. Our latest engine is one we bought with a broken rod. Had a hole in the block the size of a quarter. Welded it up and then put a fresh rod and piston and put it back together. If you want something that is low miles and drop in ready, prepare to drop some cash...
[Re: 71yelladustr]
#2472800
03/27/18 03:19 PM
03/27/18 03:19 PM
Kiddart
looks like the ones I do find are with Blown Head gaskets. found a few but with High Miles most likely out of a truck. I will continue my search. I would guess even if I had to do a rebuild it is still a fair deal if I can off all my small block stuff.
Thank you Kiddart
[Re: 71yelladustr]
#2472854
03/27/18 05:12 PM
03/27/18 05:12 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Sometimes it's easier to buy Durango or 300/Charger Magnum ,Not sure about your area but here in SE PA. a wrecked or blown up Durango/300/Charger pops up once every two weeks,$750ish-3k Also try GOVDEALS dot com, I've bought a bunch of car/trucks off of there over the last few years. , last week bought a 2010 police Charger, opening bid was $200 closing bid was $256.00 ,80k mile car hit in the rear Month ago bought a 2014 Ram 3500 6.4 45k , it was a rollover truck opening was $500, closed at $500.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: 71yelladustr]
#2502272
05/30/18 03:22 PM
05/30/18 03:22 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
The cheap stuff is usually broken or blowed up. The engine we used in the build was a core. The customer had overheated it and popped the head gaskets. I didn’t want to put headgaskets on it and risk it dropping a valve seat. So we put a set of eagles and fresh gaskets on it and rolled on. Our latest engine is one we bought with a broken rod. Had a hole in the block the size of a quarter. Welded it up and then put a fresh rod and piston and put it back together. If you want something that is low miles and drop in ready, prepare to drop some cash... I see updated numbers in your sig: 365” gen III hemi on E-85 727 trans Dana 60 10.35@131 What are the updates? Talk to me, Goose! (If you don't mind)
