Page 3 of 3 1 2 3
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2398491
11/04/17 07:14 PM
11/04/17 07:14 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
this build is outstanding! I reallt think the gen 3 hemi is the answer too mopar guys new age hot rodding!
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2398534
11/04/17 08:54 PM
11/04/17 08:54 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Are you using the stock motor mount location and using the front accessory drive for the OEM water pump and alternator?
Re: First outing with junkyard 5.7 = Win!! [Re: moparmitch] #2398603
11/04/17 11:44 PM
11/04/17 11:44 PM
Missouri U.S.A.
71yelladustr Offline OP
Missouri U.S.A.
Thanks everyone for the positive comments. The headers are botched to say the least. They are actually cheapo pacesetter 1 3/4 headers for ram pickup with early port heads. So port alignment is not even close for the eagles. Reworked a couple tubes on each side to make them fit. A good set of headers would probably make a noticeable improvement. We don't run any accessories or alternator. Used a truck timing cover and rigged a moroso pump drive to the factory water pump. The mounts are a combination of Schumacher BB perches and street and performance engine mounts.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2398691
11/05/17 08:19 AM
11/05/17 08:19 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
For the early Dak with a G3 hemi swap, might want to look at the A-body G3 Hemi headers.
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2398722
11/05/17 11:06 AM
11/05/17 11:06 AM
Missouri U.S.A.
Missouri U.S.A.
I'd be surprised if A body headers will fit. The passenger side upper control arm
Is very close to the head. The frame also angles inward directly behind the engine with the rear lower control arm mount also taking up valuable space. It's just tight.
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2398787
11/05/17 01:11 PM
11/05/17 01:11 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Just thinking out loud about the A body,
Re: First outing with junkyard 5.7 = Win!! [Re: ric3xrt] #2398877
11/05/17 03:22 PM
11/05/17 03:22 PM
Missouri U.S.A.
Missouri U.S.A.
ric3xrt I appreciate your input. I looked at different headers for hours trying to find some that I thought I could make work. Even some LS and Ford headers. I was willing to cut off the flange and weld on a hemi flange but there didn't seem to be any that looked close. So after all of that, said heck with it and bought some cheapos and went to hacking. sawzall weld
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2399345
11/06/17 02:04 PM
11/06/17 02:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'm just wondering what the early 5.7 heads would do with the same cam-combo. Maybe a little port work on the heads too. Sounds so enticing with the parts starting to flow with the Gen lll hemi.
Re: First outing with junkyard 5.7 = Win!! [Re: cudaman1969] #2445099
02/02/18 10:09 AM
02/02/18 10:09 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I wonder what the Compression ratio would be if ya ran the thicker gaskets. Wanting to do a 04 hemi and Eagles for the street..
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2445218
02/02/18 03:17 PM
02/02/18 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
when I mocked up an actual eagle head and early short block and standard head gasket it came out to around 11.5 compression. With the fast burn chambers, double quench pads, EFI, dual spark plugs, plastic intake... I would bet you would be totally fine on premium pump fuel. The only problem you might run into is if your tuner gets too agressive with the timing, these things really don't need much. Heck the apache is 10.9 and you know the factory is going to be very conservative on compression for emmisions reasons (NOX specifically). I think a low buget early 5.7 short block with a 6.1 cam and eagle heads/intake would be a buget motor to be reckoned with.
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2469706
03/21/18 02:20 PM
03/21/18 02:20 PM
K
Kiddart Offline
Kiddart  Offline
K
I keep hearing that guys are finding these JY gems for $900 to $1500 bucks. what JY and Where. around me they are like gold
Thank you
Kiddart
Re: First outing with junkyard 5.7 = Win!! [Re: Kiddart] #2469757
03/21/18 03:34 PM
03/21/18 03:34 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I usually look on craigslist. I found a nice complete core for $300 that dropped a valve seat a couple months ago. The early models seem harder to find around here though. Here are some examples in my area.
https://york.craigslist.org/pts/d/05-hemi-engine/6468093926.html
https://washingtondc.craigslist.org/doc/pts/d/57-hemi-and-trans/6530601420.html
https://annapolis.craigslist.org/pts/d/2010-dodge-ram-2500-parts/6496707097.html
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2469802
03/21/18 04:55 PM
03/21/18 04:55 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
They seem to go fast when they are cheap. I have a couple extras, so I don't even look for more now because I don't need more junk laugh2
Last one I bought was a '12 with 34k but block was broke. Paid less than heads are worth. Plus got a perfect rotating assembly, lifters, rockers, etc.
09 and up are cheaper it seems than the earlier ones. Guess it's a supply/demand thing.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2471969
03/25/18 08:48 PM
03/25/18 08:48 PM
Missouri U.S.A.
Missouri U.S.A.
The cheap stuff is usually broken or blowed up. The engine we used in the build was a core. The customer had overheated it and popped the head gaskets. I didn’t want to put headgaskets on it and risk it dropping a valve seat. So we put a set of eagles and fresh gaskets on it and rolled on. Our latest engine is one we bought with a broken rod. Had a hole in the block the size of a quarter. Welded it up and then put a fresh rod and piston and put it back together. If you want something that is low miles and drop in ready, prepare to drop some cash...
10.02@134
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2472800
03/27/18 03:19 PM
03/27/18 03:19 PM
K
Kiddart Offline
Kiddart  Offline
K
looks like the ones I do find are with Blown Head gaskets. found a few but with High Miles most likely out of a truck. I will continue my search. I would guess even if I had to do a rebuild it is still a fair deal if I can off all my small block stuff.
Thank you
Kiddart
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2472854
03/27/18 05:12 PM
03/27/18 05:12 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Sometimes it's easier to buy Durango or 300/Charger Magnum ,Not sure about your area but here in SE PA. a wrecked or blown up Durango/300/Charger pops up once every two weeks,$750ish-3k
Also try GOVDEALS dot com, I've bought a bunch of car/trucks off of there over the last few years. , last week bought a 2010 police Charger, opening bid was $200 closing bid was $256.00 ,80k mile car hit in the rear
Month ago bought a 2014 Ram 3500 6.4 45k , it was a rollover truck opening was $500, closed at $500.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: First outing with junkyard 5.7 = Win!! [Re: 71yelladustr] #2502272
05/30/18 03:22 PM
05/30/18 03:22 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I see updated numbers in your sig:
365” gen III hemi on E-85 727 trans Dana 60
10.35@131
What are the updates? Talk to me, Goose! (If you don't mind)
Re: First outing with junkyard 5.7 = Win!! [Re: Kiddart] #2505342
06/06/18 06:49 PM
06/06/18 06:49 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here are a couple (Not mine):
https://detroit.craigslist.org/okl/pts/d/2004-dodge-ram-57-hemi-engine/6607164665.html
https://detroit.craigslist.org/wyn/pts/d/hemi-57/6609283414.html
Rich H.
Esse Quam Videri
Page 3 of 3 1 2 3
