Re: A-body 727 trans
[Re: SIKPUP]
#2398497
11/04/17 07:22 PM
11/04/17 07:22 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
The big block 727 is the same length as the big block Lakewood bell housing with the short A body 4 speed. this is not true Lakewood bellhousing is the same dimension front to rear as a stock bellhousing (stock are the same piece between A/B/E bodies with same engine) A-body bellhousing & 4-speed = same length as 904 B-body bellhousing & 4-speed = same length as 727
