A-body 727 trans #2398314
11/04/17 09:49 AM
11/04/17 09:49 AM
K
karengarneau Offline OP
K
Never had much experience with auto cars but I do know that the 4 spd are different lengths, A,B,E etc. My question is, is it the same with the automatic transmissions or will a E-body trans work in an A-body without any modifications. Thanks for your help.
Re: A-body 727 trans [Re: karengarneau] #2398323
11/04/17 10:39 AM
11/04/17 10:39 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
All car 727's are the same length as far as I know. Some trucks use a stubby one.
Re: A-body 727 trans [Re: buildanother] #2398326
11/04/17 10:50 AM
11/04/17 10:50 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
iagree
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body 727 trans [Re: karengarneau] #2398377
11/04/17 01:31 PM
11/04/17 01:31 PM
BDW Offline
BDW  Offline
Re: A-body 727 trans [Re: karengarneau] #2398379
11/04/17 01:32 PM
11/04/17 01:32 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
The big block 727 is the same length as the big block Lakewood bell housing with the short A body 4 speed.
Re: A-body 727 trans [Re: karengarneau] #2398386
11/04/17 01:50 PM
11/04/17 01:50 PM
K
K
I was under the impression that they were all the same length. I acquired a 727 trans that supposed to have come out of a 1972 cuda. I am going to install in a 68 GTS. hopefully it will go smoothly no major surprises. Anything else anybody can think of, will be appreciated. Thanks to all.
Re: A-body 727 trans [Re: karengarneau] #2398402
11/04/17 02:55 PM
11/04/17 02:55 PM
A,B,C,E BB and SB 727 are the same length for every body style from 1965 and up scope The block bolt patterns are not the same but every thing else is including the converters and starters shruggy
Re: A-body 727 trans [Re: SIKPUP] #2398497
11/04/17 07:22 PM
11/04/17 07:22 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
this is not true frog
Lakewood bellhousing is the same dimension front to rear as a stock bellhousing (stock are the same piece between A/B/E bodies with same engine)
A-body bellhousing & 4-speed = same length as 904
B-body bellhousing & 4-speed = same length as 727
