4 LINK SUGGESTION #2394940
10/29/17 05:28 PM
10/29/17 05:28 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
What do I need to look for when choosing a 4 link? Any brand better than others?
Re: 4 LINK SUGGESTION [Re: A/MP] #2394960
10/29/17 06:16 PM
10/29/17 06:16 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Most name brand companies are pretty closely matched. Most kits do not come with heim ends. If you find a four link kit with heim ends, you might save yourself a couple of dollars. Get a kit with the thickest lower bars they make. I like the Smith Racecraft stuff. I bought an outlaw ladder bar kit from them, came with really nice, thick four link axle brackets. Had good prices, too.
[image][/image]
Re: 4 LINK SUGGESTION [Re: A/MP] #2394994
10/29/17 07:11 PM
10/29/17 07:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Smaller bolts give more adjustment. Reinforced brackets in hole area keep hole from wollering. Quality ends are worth the $$
Re: 4 LINK SUGGESTION [Re: FastmOp] #2395023
10/29/17 08:38 PM
10/29/17 08:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Get one with an anti roll bar. I like the S&W kits myself.
Re: 4 LINK SUGGESTION [Re: A/MP] #2395056
10/29/17 09:43 PM
10/29/17 09:43 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Yes ARB bar makes a huge difference.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 4 LINK SUGGESTION [Re: A/MP] #2395467
10/30/17 04:23 PM
10/30/17 04:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO get one with the MOST adjustability you can afford! Some of the kits out there have 7-8 holes in the front bracket. IMO those will likely find you a good place to work with but changes that you make may have a large effect on IC. IMO if you can afford one with more adjustability(smaller bolts or sliders)the better off you will be in the end.
Re: 4 LINK SUGGESTION [Re: A/MP] #2397648
11/03/17 01:17 AM
11/03/17 01:17 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
They aren't all the same and don't all have the correct geometry. Buy from a real race car shop, not someone who does street rods and other crap. Look at the brackets offered by Bickel and RJ for up to date designs, i.e. hole sizes, locations and spreads, provisions for shocks, etc. Different units have different provisions for shocks, wheelie bars, roll bars, etc. Get the one that suits how you will be doing your housing. I don't think anyone does them with .750" holes anymore, but avoid those. 1/2" holes with the corresponding tight hole spacing are the best way to go. Don't use junk rod ends.
Re: 4 LINK SUGGESTION [Re: A/MP] #2398363
11/04/17 12:39 PM
11/04/17 12:39 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Make sure whatever you choose has a diagonal, or wishbone of good size. I see decent 4 link kits that have small dia diagonals. They should be same size as the rest of the bars. Basically something the driveshaft can't break if it breaks. No fun going rear wheel steer.
