Re: 4 LINK SUGGESTION
[Re: A/MP]
#2394960
10/29/17 06:16 PM
10/29/17 06:16 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Most name brand companies are pretty closely matched. Most kits do not come with heim ends. If you find a four link kit with heim ends, you might save yourself a couple of dollars. Get a kit with the thickest lower bars they make. I like the Smith Racecraft stuff. I bought an outlaw ladder bar kit from them, came with really nice, thick four link axle brackets. Had good prices, too.
[image][/image]
[Re: A/MP]
#2395056
10/29/17 09:43 PM
10/29/17 09:43 PM
Posts: 326 Alberta
Wookie316
Alberta
Yes ARB bar makes a huge difference.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: A/MP]
#2395467
10/30/17 04:23 PM
10/30/17 04:23 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
IMO get one with the MOST adjustability you can afford! Some of the kits out there have 7-8 holes in the front bracket. IMO those will likely find you a good place to work with but changes that you make may have a large effect on IC. IMO if you can afford one with more adjustability(smaller bolts or sliders)the better off you will be in the end.
[Re: A/MP]
#2397648
11/03/17 01:17 AM
11/03/17 01:17 AM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
They aren't all the same and don't all have the correct geometry. Buy from a real race car shop, not someone who does street rods and other crap. Look at the brackets offered by Bickel and RJ for up to date designs, i.e. hole sizes, locations and spreads, provisions for shocks, etc. Different units have different provisions for shocks, wheelie bars, roll bars, etc. Get the one that suits how you will be doing your housing. I don't think anyone does them with .750" holes anymore, but avoid those. 1/2" holes with the corresponding tight hole spacing are the best way to go. Don't use junk rod ends.
