F body rear in A body #239560
03/01/09 02:09 AM
03/01/09 02:09 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
does an F body rear end fit into an A body? I know the rear is wider by a few inches, but will there still be enough tire clearance in the wheel well? and does it still bolt up to the rest of the car? I know the drive shaft also has to be shortend too. the car in question is for my 71' scamp..
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: F body rear in A body [Re: mopars_1] #239561
03/01/09 03:28 AM
03/01/09 03:28 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Besides the rear being wider, the spring perches are different and would have to be changed. Not a big deal if you can weld, and the new perces are about $13 from Mopar. I have seen F-body rears in Dusters and Demons/Dart Sports, but they have an open wheelwell. The "slab side" A-bodies (Dart, Valiant, Scamp) dont have the room for a wider rear. Its not worth the trouble. Get ahold of an A-body 8 1/4 rear. They are still pretty easy to find
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: F body rear in A body [Re: 69L78Nova] #239562
03/01/09 11:55 AM
03/01/09 11:55 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
there is a guy on the /6 site that had a 70 Valiant (4 dr) that had an F body rear in his for a while; I dont remember why he took it out but it wasn't because the F body rear blew out, or such. IIRC he found an 8-3/4 which was what he was originally wanting.
Re: F body rear in A body [Re: 69L78Nova] #239563
03/01/09 02:41 PM
03/01/09 02:41 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
thanks for the info. I bought the axle being told it was for an A body, but after some measuring found it was wider than what I was really needing. aw well I guess. thanks again
1937 Plymouth PT50
Re: F body rear in A body [Re: mopars_1] #239564
03/01/09 05:44 PM
03/01/09 05:44 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Now I have a 65 Cuda and they have monsterous sized rear wheelwells for some reason. I am using a F body 8 1/4 under mine. I can run my 78 LRT's rear tires and wheels under it, 275/60 HR 15 on a 8" rim if its only me and the wife in the Cuda. If I have a rider in the rear the tires rub on the springs. It does fit on the stock springs without binding. I have run it this way for 8 years and 50,000 miles.
Just for info, I am running a 3.55:1 Suregrip from a 8 3/8 Dodge Van in the 8 1/4 housing that came with 2.94:1 open gears. The truck 8 3/8 is the same as a car 8 1/4, go figure. DaveJ
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: F body rear in A body [Re: Dave_J] #239565
03/01/09 08:22 PM
03/01/09 08:22 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
very good to know thanks!!
1937 Plymouth PT50
Re: F body rear in A body [Re: Dave_J] #239566
03/01/09 08:28 PM
03/01/09 08:28 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Now THAT I'd have to see in person
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: F body rear in A body [Re: Dave_J] #239567
03/02/09 01:15 PM
03/02/09 01:15 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I just want to add to this to clearify. I removed this rearend from outunder an Aspin R/T. I did not figure it had been changed as it was just as rusty as the rest of the car. 90% of the Aspin R/T was gone. DaveJ
65 Formula S Cuda
Re: F body rear in A body [Re: Dave_J] #239568
03/03/09 04:02 PM
03/03/09 04:02 PM
Scottsdale, AZ
K
kenz Offline
kenz  Offline
K
Scottsdale, AZ
Do you know what the drum to drum width is of the F-Body rear?
Thanks,
Ken
