Re: 511 project hp falls short of target
[Re: mopar dave]
#2395105
10/29/17 11:13 PM
10/29/17 11:13 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
You are gonna have to take it to the track & tune 1st
[Re: mopar dave]
#2395153
10/30/17 01:01 AM
10/30/17 01:01 AM
BradH
Read your post quickly and I'm just gonna rattle off what came to mind: 1. F**k those dyno software programs. I own four of them, ranging from cheapo to "Professional" level and NONE of them give results that match what I've found in the real world without my gaming the inputs significantly to tweak the results.
2. How much does your car weigh with driver?
3. Is it a stick car or an automatic? If auto, what type of converter?
4. How much gear do you run and with what size & type of tires?
5. What are you running for fuel? Have you tested different timing settings?
6. What's your performance goal? I don't mean "700 HP on pump gas", I mean an ET goal. If the car ran 9.99, would it be legal at the track vs. only going 10.00?
7. "Seat of the pants" testing on the street is next to worthless. Too many variables, too little traction, etc. I've done things in the past that I'd swear would show up as improvements on the track that didn't, but my "butt dyno" told me it would.
8. Until you either pull the engine and put it on a reputable engine dyno OR spend a solid day at track working on the tune, so that you can get some real-world #s, you have no idea beyond an educated guess what that engine's making.
[Re: mopar dave]
#2395154
10/30/17 01:03 AM
10/30/17 01:03 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
The track always shows you what you have. I think it would be lucky to run a 10.50 the way it sits. what are you putting it in ? my 505 makes maybe 615 and has gone 10.53 @ around 3660lbs . I only have cnc 440 source heads and 4150 carb. until you run it you are only second guessing . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: mopar dave]
#2395167
10/30/17 01:40 AM
10/30/17 01:40 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
With a few tweeks you didnt make your smallblock would have run 9's. Lots of very similar combos out there doing so
[Re: mopar dave]
#2395177
10/30/17 02:08 AM
10/30/17 02:08 AM
B3422W5
Portage,michigan
If it would of stayed together it would been in the 9.90's im sure. Those indys were maxed out per Dwayne Welder and it was 13:1 compression and 80# lighter. I like the BB though. Ill get it figured out. Its all just time and money right now. I think most would love the way it runs, alot of fun to street drive. My goals are usually lofty thats all. Didnt you run 10.30's with it?
[Re: mopar dave]
#2395193
10/30/17 03:23 AM
10/30/17 03:23 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
Bigger heads, bigger carb. will make more power and go faster My old 518 C.I. 400 pump gas stroker(4.375x4.300 stroke) ran 10.30 with the ported Eddy RPM and the low deck six pack at 127.+ MPH a bunch of times. Swap heads to a set of Indy SR M.W. ports and a 400-3 intake with a single 1050 dominator and it ran low tens at 134.+ MPH, same cam, a little more compression, 84 CC heads to 76 CC heads, 10.29 to 1 to 10.76 to 1 comp ratio That car weighed 3450 Lbs. with me in it, it ran that through the 3.0 inch full exhaust system to the rear bumper and the air cleaners on both set ups
[Re: mopar dave]
#2395289
10/30/17 12:13 PM
10/30/17 12:13 PM
fast68plymouth
So. Burlington, Vt.
Without dyno testing it, you'll never know what it really makes....... Period.
You want 700hp...... For sure? Put it on the dyno and start swapping parts til you get there. Then put it in the car and see what it runs.
The time slip is a report card on how well the entire combination works..... Not just how good the motor is, or how much power it makes.
I've seen first hand both ends of the spectrum on that. Cars that actually exceed the performance of the calculators, and cars that don't even come close.
I just had a motor on the dyno about a month ago..... Made 443hp. Two weeks ago it was in the car at the track for a test n tune. Went 11.34@117, at 3600lbs. Shows 445 on the Moroso chart.
I know if I had that pile of parts for your 511 on the dyno, I'd be expecting more than 650hp.
