quench, gasket bore and compressed height
#2394226
10/28/17 02:14 PM
10/28/17 02:14 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
If I'm using Felpro 1039 headgasket with 4.590" bore and 0.051 CH, on a 400 block +0.020" so 4.362" bore... that makes 0.228" bore difference between block and headgasket... this means 0.114" difference between cylinder wall and gasket all around being with 0.051" gap between block and head... will this area affect quench ?
DESPITE ALL THE REST OF DISCUSSION AND GET FOCUSSED ON THIS PLEASE!!!!
ONCE AGAIN! wondering if this area around the cylinder bore being 0.051" will affect quench efficiency still if my make sit my pistons quench pad still at 0.040 on the 452 heads.
Re: quench, gasket bore and compressed height
[Re: ahy]
#2394243
10/28/17 03:23 PM
10/28/17 03:23 PM
Posts: 10,763 North Dakota
6PakBee
North Dakota
I think that the benefit of quench would be affected, but so minimally I doubt you could tell the difference. But practically speaking, other than having a custom head gasket made, what options do you have other than to live with what you have?
[Re: NachoRT74]
#2394244
10/28/17 03:25 PM
10/28/17 03:25 PM
NachoRT74
Valencia, España
I can't afford $100 per gasket, plus international shipping
other options... use the felpro kit gaskets ( 0.039 ) and felpro copper shims ( 0.020 ), decking block even lower ( 0.010 more ). All thse parts in hands.
reduce CR will be a benefit in fact
[Re: NachoRT74]
#2394457
10/28/17 11:38 PM
10/28/17 11:38 PM
6PakBee
North Dakota
I guess what I meant with living with what you have is that once you are at minimum quench distance, other than having a custom gasket made to your bore size, you are pretty much out of options. Sorry I wasn't clearer.
[Re: 6PakBee]
#2394620
10/29/17 03:48 AM
10/29/17 03:48 AM
NachoRT74
Valencia, España
I guess what I meant with living with what you have is that once you are at minimum quench distance, other than having a custom gasket made to your bore size, you are pretty much out of options. Sorry I wasn't clearer. Cool!
[Re: 360view]
#2394783
10/29/17 01:36 PM
10/29/17 01:36 PM
RapidRobert
I'm thinking that a gasket bore clos(er) to the bore perimeter would be a somewhat more efficient eng by eliminating the unburned fuel/air in the aforementioned "crevice volume" but this does not make/break quench efficiency that you asked about since the piston plateau/head interface (the quench area) is inward further from that perimeter. A gasket with a smaller bore would get a person closer to a "spot on" engine but whether it would be worth it to you to add that expense I cannot say. Just me I sleep better at night (& function better in the day) knowing I built the most efficient eng that my knowledge (& the collective knowledge of my fellow Moparts brothers) will allow me to accomplish (& my budget!). I gotta go, some hand egg is on the menu for this morning.
[Re: NachoRT74]
#2394842
10/29/17 02:52 PM
10/29/17 02:52 PM
NachoRT74
Valencia, España
yes! I'm pointing out in the future to the cometic headgasket on 4.380 bore 0.051 thickness, but can't make it now. Headgaskets are easy to replace in a close future though, but need to assembly the car ASAP which what I have in hands right now http://www.cometic.com/i-24768321-chrysl...-bore-each.htmlit seems after several decking block corrections I can get pistons around 0.010-0.013 out of the bore... IF FINALLY THEY MAKE IT RIGHT! will need to equalize the quench pads on combustion chambers too ( it seems the deeper one is around 0.120", then maybe cut some ( 0.020" ) the heads to get that area on 0.095-0.100" deepness rate to match the KB215 pistons quench pad step
[Re: NachoRT74]
#2394851
10/29/17 03:04 PM
10/29/17 03:04 PM
NachoRT74
Valencia, España
by I could understand that "crevice volume" area is prone to preignition due carbon deposits there becoming on a pocket for them! sooooo... the quench job could be a lost job getting another problematic area now.
[Re: NachoRT74]
#2394858
10/29/17 03:11 PM
10/29/17 03:11 PM
NachoRT74
Valencia, España
well thinking it now, the regular 0.039 headgasket is also bigger bore, just not that big ( barelly 0.050 to my actual cylinder bore, 3/4 less than the 1039 gasket), but still becoming on a pocket for carbon deposits
[Re: ek3]
#2395257
10/30/17 10:57 AM
10/30/17 10:57 AM
NachoRT74
Valencia, España
I think you are over thinking this... yes, probably you are right, but an opportunity to learn about I still dunno about all this tech stuff and therms about, combustion, ignition times and everything related. I was mainly worried about preignition ( pinging ) problems due this pocket around cylinder using this bore diameter gaskets after work on all the quench stuff.
[Re: NachoRT74]
#2395575
10/30/17 07:14 PM
10/30/17 07:14 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
yes! I'm pointing out in the future to the cometic headgasket on 4.380 bore 0.051 thickness, but can't make it now. Headgaskets are easy to replace in a close future though, but need to assembly the car ASAP which what I have in hands right now http://www.cometic.com/i-24768321-chrysl...-bore-each.htmlit seems after several decking block corrections I can get pistons around 0.010-0.013 out of the bore... IF FINALLY THEY MAKE IT RIGHT! will need to equalize the quench pads on combustion chambers too ( it seems the deeper one is around 0.120", then maybe cut some ( 0.020" ) the heads to get that area on 0.095-0.100" deepness rate to match the KB215 pistons quench pad step Instead of using .039 and a shim just cut the open part of the chamber deeper and do not use the shim. That area of the chamber is .300 thick, taking an extra .020 out of that area will not be a problem.
[Re: NachoRT74]
#2395805
10/31/17 12:43 AM
10/31/17 12:43 AM
NachoRT74
Valencia, España
dogdays:
yes that was my thought, but my doubt was that because per what I have read on several places the quench/squish area can be on 0.050" rate and still be good even the advice is around 0.040"
John:
that could be good too! and will make to keep the heads unmilled, saving from ANOTHER mistake from machine shop. However that could make also to get really close the piston diameter out of the quench pad close to the head around the combustion chamber to allmost 0.020" I think... isn't that some dangerous ? I recall the combustion chamber bore is sligthly smaller bore than the cylinder bore... isn't ?
Wouldn't actually need to cut 0.020" but maybe the 0.010-12 extras the thicker felpro headgaskets got with bigger bore, and keep using the 0.39 with small bore... in another words, cut the combustion chamber quench area same ammount the pistons leaves the deck. Maybe in fact they are actually close to what I need. I'm pretty sure this area is deeper than the piston quench pad height and maybe close to what I need as mentioned on a previous reply.
I will know just once the block is correctly decked and once assembled measured with clay
[Re: NachoRT74]
#2396024
10/31/17 01:20 PM
10/31/17 01:20 PM
NachoRT74
Valencia, España
making maths without actual measurements yet...
If I have to get the quench area deepness on heads equalized up to .120" taking the deeper one as a starting point( to be confirmed, thats was a rude measurement I made once ), plus .039" of gasket makes .159"
less .095" of piston step and .012" ( or so ) of pistons leaving the deck... total 0.052" of quench. It seems not to be bad. To be used on 95 octanes gas in Vzla, and once move to Spain, probably 98 octanes
Definitelly I'm overthinking the deal with the 0.051 gasket!!!
just thinking on the area out of the combustion chamber, being smaller than the piston bore, that should be on 0.027" rate. Am I fine with it ?
That will get me also the static CR close to 10.5 on the iron heads.
I have 6 and 7 NGKs heat range spark plugs to play... also platinum Bosch plugs WR9FP
Opinions
