Engine Heat Issue #2394247
10/28/17 03:29 PM
10/28/17 03:29 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Melted 2-pistons.
Tore down and changed cam, pistons/rings,head gasket thickness.
Lowered cr. from 9.1 .
Now 8.86 cr.
Moly rings .025 gap./.008 piston clearance.
Gasket .098 Cometic,, Ross flat tops.
Old cam 236/241@ .050 110 c/l.
New--248/248@.050 114 c/l.
So anyway,would run 160ish 180ish all day anywhere before,now 180 to 200* and is boiling fuel in the carb. after you park and try to restart.
Timing 30* with vacuum advance just like before.
Flushed cooling system twice,no improvement.
Richened cruise AFR no improvement.
Took hood off,no improvement.
Seems to get hot driving then when you stop,idle and or shut it off the heat in the engine shows itself.
If you never stop the water temp. holds steady.
Only thing I can figure is its sealed up better/rings-pistons and is producing more heat.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Engine Heat Issue [Re: 6bblFLASH] #2394252
10/28/17 03:43 PM
10/28/17 03:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why moly rings? They are not the best for supercharged motors and do not take heat well. IMO.
I would still say your lean making all the extra heat. twocents
Re: Engine Heat Issue [Re: 6bblFLASH] #2394287
10/28/17 05:13 PM
10/28/17 05:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I was thinking it's lean.
Re: Engine Heat Issue [Re: 6bblFLASH] #2394324
10/28/17 06:56 PM
10/28/17 06:56 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Another vote for it being Lean.
Fuel curve requirements will often change with a cam change.
Re: Engine Heat Issue [Re: 6bblFLASH] #2394333
10/28/17 07:22 PM
10/28/17 07:22 PM
P
Porter67 Offline
Porter67  Offline
P
How much time on the new motor?
Re: Engine Heat Issue [Re: Porter67] #2394337
10/28/17 07:37 PM
10/28/17 07:37 PM
N.E. Ohio
N.E. Ohio
About 100 miles
Re: Engine Heat Issue [Re: 6bblFLASH] #2394341
10/28/17 07:43 PM
10/28/17 07:43 PM
P
Porter67 Offline
Porter67  Offline
P
Are you sure something isnt tight in the motor causing more heat?
Myself cant go with the sealed up better causing the heat as that would indicate your last build didnt seal properly from day one.
Maybe run it a bit more?
Love the setup btw.
Re: Engine Heat Issue [Re: Porter67] #2394384
10/28/17 09:25 PM
10/28/17 09:25 PM
N.E. Ohio
N.E. Ohio
I am wondering about if the winter blend gas is in the pumps?
It would definitely boil at lower temps.
It has been usually warm in Ohio.
Not sure how it would effect what my wideband sees.
Maybe its lean any way.
Even though I have fattened it up?
Re: Engine Heat Issue [Re: 6bblFLASH] #2394392
10/28/17 09:43 PM
10/28/17 09:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
How is the timing curve set up?
Off the top of my head.....if it ends up not being a lean condition.....
Longer duration cam(lower cyl pressure) with a much earlier ex opening point, in a low comp motor will tend to have increased ex temps, which will put more of that heat into the the water jackets surrounding the ex ports.
Less than optimal timing under those conditions just adds to the high ex temps.
Re: Engine Heat Issue [Re: fast68plymouth] #2394396
10/28/17 09:47 PM
10/28/17 09:47 PM
IN
ahy Offline
ahy  Offline
IN
I see a small pusher fan in front of the radiator. Is there a bigger fan behind?
If the pusher is the primary fan, its not enough and explains why it is hot when you slow down.
Re: Engine Heat Issue [Re: ahy] #2394403
10/28/17 09:57 PM
10/28/17 09:57 PM
N.E. Ohio
N.E. Ohio
Timing all in about 1500.
Yes most aggressive mechanical fan I could find belt driven behind radiator.
If I get to drive it much more this see seas I think I am going to slow the supercharger down.
It is 2.72 times crank speed.
I have a pulley to get 2.32 crank s peed
Re: Engine Heat Issue [Re: 6bblFLASH] #2394443
10/28/17 11:19 PM
10/28/17 11:19 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Worked on a few blown engines years ago and it always seemed like they wanted more fuel. They both really responded to a fat mixture especially on the idle circuit. One had a big B&M supercharger and we always had temp issues and after we put a pair of race 750 Holley carbs it ran much cooler without changing anything else.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Engine Heat Issue [Re: fourgearsavoy] #2394485
10/29/17 12:14 AM
10/29/17 12:14 AM
N.E. Ohio
N.E. Ohio
Well can't argue with results.
I will try more fuel and see what happens.
Re: Engine Heat Issue [Re: 6bblFLASH] #2394496
10/29/17 12:28 AM
10/29/17 12:28 AM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By 6bblFLASH
Melted 2-pistons.
Now 8.86 cr.
The engine running temps you stated didn't melt those pistons. Nothing wrong with those operating temps. Heat soak is normal on shut down. Melted pistons came from high cylinder pressure along with a lean condition, possibly wrong heat range plugs, and crap pump gas. Got enough fuel pump to keep up with the boost? Running ported vacuum advance verses manifold vacuum? Slugs are a little loose and ring end gap is a little tight IMO.
Fastest 300
Re: Engine Heat Issue [Re: 6bblFLASH] #2394506
10/29/17 12:44 AM
10/29/17 12:44 AM
Ohio
lockjaw-express Offline
Ohio
Roots compressors get VERY HOT! The Aluminum soaks up heat like crazy, and putting a carb on top is a lousy idea, because the fuel spray vaporizes so quickly that it burns very lean.
To do it right with gas for the street, I would inject the gas directly into the intake runners. Much better.
I set a few cars back in the late '80s for hot rodders, and carbs sitting on top of a hot roots compressor never worked well, and since they pushed the issue, I went with 2 750 DP carbs, jetted VERY Rich, and the one that worked best was a mechanical enderle injected into the runners, but was not very streetable, but ran great at the track.
Re: Engine Heat Issue [Re: 6bblFLASH] #2394510
10/29/17 12:47 AM
10/29/17 12:47 AM
Ohio
Ohio
One idea is to buy a Holley HP and MPFI system, injecting into the intake runners, and let the ECU control the timing and fuel...that would be very cool!
My 2 cents
Re: Engine Heat Issue [Re: lockjaw-express] #2394639
10/29/17 07:46 AM
10/29/17 07:46 AM
Cincinnati, Ohio
Cincinnati, Ohio
I did not want to go negative on my post above, but yea your right. Carbs suck for a blown engine, then the OP is wanting to run ethanol pump gas in his blown engine? WTH do you expect? 30° timing is too much, I'd go 25° max and put some decent gas in the thing. Why run pump gas in a blown engine? It's blown and needs good gas no matter what the compression is! At least straight 91 octane gas with no ethanol! Straight 91 is better than 93 ethanol for a blown engine.
Then like I said moly rings are all wrong for a blown motor, good luck with that!
Down here in Cincinnati they did away with the summer mix gas, we have the same vapor pressure gas all year long now. My god put some good gas in that thing!!
I have had several injected race engines that would have run fine on the street and we out ran EVERY carb we raced against when we were quick 8 racing.
I could have drove this 632" donovan big chief on the street it was tuned so well.
I built this motor in 1993.
Then ran this for 9 years.
Re: Engine Heat Issue [Re: Challenger 1] #2394643
10/29/17 08:03 AM
10/29/17 08:03 AM
Cincinnati, Ohio
Cincinnati, Ohio
I did say several above, this was a 572" BB chevy with Dart 360 heads on it. I was the 11th 4 second club member in 1991. It could have been street driven.
Re: Engine Heat Issue [Re: 6bblFLASH] #2394683
10/29/17 11:29 AM
10/29/17 11:29 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
since no one asked, I will, how much boost you running? That will help determine how much timing you should be running. Also, I would love to see a pic of a plug.
Joe
Without Data, you’re just another guy with an opinion.
Re: Engine Heat Issue [Re: sr4440] #2394712
10/29/17 12:14 PM
10/29/17 12:14 PM
N.E. Ohio
N.E. Ohio
5lbs.
Occasionally I will see 6lbs.
