went to track today #239418
02/28/09 11:18 PM
02/28/09 11:18 PM
Cumberland County, NJ
coronetkid Offline OP
so i went to the track today this is what happened. had a pair of used hoosiers on my 383 coronet. after playin with jets 5 times i arrived 79 in the front and 83 in the back. with 14 lbs in the slicks i ran my best time. 13.3 @100 mph my 60' was 1.9 this was my best run (was actually expecting more but what are you gonna do) i had 9 runs and got better with every pass. with the 3.55 gears i was shifting into 3rd as i went through the traps. i am going to change out to 4.10. my question is how much improvment will i see with gear swap? will this help with my 60'?
Re: went to track today [Re: coronetkid] #239419
02/28/09 11:29 PM
02/28/09 11:29 PM
IMHO, not very much, if any, if you have a good converter......100MPH is enough to go 12.90's, with a looser converter, the tires not spinning, even with 3.55's........been there, done that in quite a few different cars......
Re: went to track today #239420
02/28/09 11:37 PM
02/28/09 11:37 PM
i have an ati 3500 stall in the 727 now
Re: went to track today [Re: coronetkid] #239421
03/01/09 03:57 AM
03/01/09 03:57 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I don't know, my street car went 13.9/3.23 13.6/3.91 13.1@105/4.56. That was with a 26" tire too. 383 with a xe284 cam. When I ran 3.23s I was going thru the traps at 6500 in second. I think you need gears, especially if its heavy cammed. The only way to drop your 60' is a big (5000) convertor.
Rem
Re: went to track today [Re: coronetkid] #239422
03/01/09 09:14 AM
03/01/09 09:14 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Everything else staying the same (including weather conditions) and only changing the gear, maybe a 0.10 in the 60'. If you get the 60' improvement you'll get 0.15 to 0.2 overall.
Getting a street car like yours to 60' better than 1.9 is difficult at your power level.
Let us know what you find out
Re: went to track today #239423
03/01/09 09:43 AM
03/01/09 09:43 AM
Q
Quicktree Offline
Quicktree  Offline
Q
with the squeeze, 3500 is not a good race converter. not anywhere close.
Re: went to track today [Re: coronetkid] #239424
03/01/09 10:01 AM
03/01/09 10:01 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Yes the 4.10's will definitely help your 60 especially with the 383 trying to get that thing rolling. I would go to 4.30's if you are buying new gears, they are a nice compromise between 4.1 and 4.56.
I went from 3.23's in my 69 roadrunner with a 440 running 12.5's most of the time to 4.30's and 1st pass it ran 12.15 and I only made 3 passes and I got it down to 12.09.
That was a street car, 10:1 pump gas 440 with a .509 cam, 3500 stall, 3700# car with me in it.
Re: went to track today [Re: moparmanjames] #239425
03/01/09 10:36 AM
03/01/09 10:36 AM
You guys that are picking up by going to a lower gear have a relatively tight converter.....anything under 4K I consider tight........I guarantee that you can put a 9.5" converter that will got to 4,500 to 4,800 in that car and it'll go high 12's with 3.55's, if it's not spinning......and those converters are extremely "streetable".......
Re: went to track today [Re: coronetkid] #239426
03/01/09 10:38 AM
03/01/09 10:38 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I have a PTC 3,500 converter and get 1.81 sixty foot times on my worn out M/T drag radials at around the same power level as you. I just got a set of fresh drag radials and want to see if I can dip into the 1.7's this spring.
Mine runs 12.91 @ 103 with 3.91 gears and S/S springs. I've wittled my 60 down with launch technique (lots of practice).
Re: went to track today #239427
03/01/09 10:39 AM
03/01/09 10:39 AM
Q
Quicktree Offline
Quicktree  Offline
Q
your wasting your time Wayne some have to learn the hard way. nothing a few $$$$ and a little time wont solve.
Re: went to track today [Re: Quicktree] #239428
03/01/09 10:57 AM
03/01/09 10:57 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I learned the converter thing with a friends car. His car made me nervous as it ran real good with a 3.23 gear and a loose converter. I was thinking his swap to 3.91s would make him faster as it picked my car up 7 tenths(stock converter). Well he got his 3.91s and it ran the same times thanks to his good converter lol.
68 Barracuda Formula S 340
Re: went to track today [Re: dustergirl340] #239429
03/01/09 11:37 AM
03/01/09 11:37 AM
Prospect, PA
Prospect, PA
Good example. I could not have set this up any better.
So, if you had a 100 mph trap like the OP, that would put you at about 13.2 - plus or minus a little.
Re: went to track today [Re: moparmanjames] #239430
03/01/09 12:04 PM
03/01/09 12:04 PM
how would 4.30's act on the street? it's mostly a street car but i would like to be able to say it's a 12 sec car. would it be a better investment to put a looser converter in a street car or just go to 4.10s or 4.30s?
Re: went to track today [Re: coronetkid] #239431
03/01/09 12:07 PM
03/01/09 12:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
if it were me I would probably go with 410s and a good converter. we ran 456s and 488s on the street but no highway runs
Re: went to track today [Re: Quicktree] #239432
03/01/09 12:29 PM
03/01/09 12:29 PM
Central NC
gch Offline
gch  Offline
Central NC
Before you pick a gear what rpm are you shifting at?
My limit for street is a 4.10 with the 28" tire I usually run.Highway trips are not happening.
Re: went to track today [Re: coronetkid] #239433
03/01/09 12:32 PM
03/01/09 12:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A 383 is no more than a small block in the larger big
block housing... you need all the torque you can get.
The stall in the converter lets you get into the torque
range quicker, the gear is the multiplier for the torque
Re: went to track today *DELETED* [Re: coronetkid] #239434
03/01/09 12:55 PM
03/01/09 12:55 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Post deleted by nhramark
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: went to track today [Re: nhramark] #239435
03/01/09 12:57 PM
03/01/09 12:57 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
4.30's on the street with street tires would be a blast......for a while. That's a lot of gear for a short tire and you will be zinging the tach constantly and maintaining highway speeds will be brutal. It will get real old, real fast.
A loose converter would be a better "investment". I know several guys with loose converters in the 5000 rpm range and their cars are very streetable. Not to say the gears you have are optimum, but if you're only going to change one thing, I'd go with the converter before the gears.
I also suggest contacting PTC converters, that's what I run and am very happy with the performance, price, and especially the service.
Re: went to track today #239436
03/01/09 02:58 PM
03/01/09 02:58 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I agree with that, but I'm not a big fan a 383 street car with two gears...
Re: went to track today [Re: gch] #239437
03/01/09 03:43 PM
03/01/09 03:43 PM
i'm running 28 inch tires and i go through the trap at around 6500 rpm in sec gear. i'm basically shifting into 3rd as i cross
