SB oil pan gasket 360 #2394136
10/28/17 04:03 AM
10/28/17 04:03 AM
CA.
RAY1969CARS Offline OP
CA.
Hi guys I've been looking on line to see pointers on a good way to install oil pan gasket and rear main seal need your help with tips and witch silicone here a few tube video I've seen p.s I was always told not to put silicone on both sides of the gasket
https://youtu.be/HGAm1MvHnRU
https://youtu.be/VdUo-Ts4Acw
I'm seen that guys do it a lot of ways with the bolts start in the middle of working way out start in the middle of working way out both ways and do the end of last ???? Idk
Re: SB oil pan gasket 360 [Re: RAY1969CARS] #2394138
10/28/17 04:43 AM
10/28/17 04:43 AM
if your working on a Chevy use the Chevy techniques, if not, don't tsk
As far as using silicone on both sides of any gasket is a big NO NO in my opinion tsk
I would buy a decent gasket sealer adhesive like Gasacinch to hold the side gaskets in place on the block and a tiny dab of adhesive silicone sealer, not gasket maker silicone, in each of the four corners where the oil pan gaskets meet the rear main cap and the timing cover up front. I do coat both sides of the gasket with the sealer and let it dry to seal both sides before installing the gasket on the block up
Then install the oil pan with all the bolts in place and slowly tighten them up evenly on both sides until the bolts start to get snug, once that is done use the factory torque specs on the bolts three or four times letting the gasket set for 5 to 10 minutes between each tightening up scope
IHTHs thumbs
Re: SB oil pan gasket 360 [Re: RAY1969CARS] #2394184
10/28/17 12:30 PM
10/28/17 12:30 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Use the felpro 1 piece rubber gasket with a little sealer on the edge of the front cover and rear brg cap works fine
Re: SB oil pan gasket 360 [Re: scottb] #2394191
10/28/17 12:57 PM
10/28/17 12:57 PM
CA.
CA.
Fel-Pro makes a one peace gasket for an LA motor?
Re: SB oil pan gasket 360 [Re: RAY1969CARS] #2394295
10/28/17 05:29 PM
10/28/17 05:29 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I believe they do for a 360 because of the Magnum engines. I have never tried one though.
68 Barracuda Formula S 340
Re: SB oil pan gasket 360 [Re: Bad340fish] #2394352
10/28/17 08:02 PM
10/28/17 08:02 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
They work. Have one on my R3 360.
Matt
Re: SB oil pan gasket 360 [Re: MattW] #2394393
10/28/17 09:44 PM
10/28/17 09:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Matt
Do the LA 360 engines have the groove in the real main bearing cap like the Magnum engines? I machined my 340 cap so I could use the magnum rear sump pan with that one piece gasket. Not sure about the early 360 though. It needs that groove to work.
Re: SB oil pan gasket 360 [Re: RAY1969CARS] #2394394
10/28/17 09:45 PM
10/28/17 09:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If scottb said it works, it works
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SB oil pan gasket 360 [Re: MattW] #2394483
10/29/17 12:13 AM
10/29/17 12:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Matt
I got one of the rare R blocks that takes a 340 pan or I would find out lol.
Re: SB oil pan gasket 360 [Re: RAY1969CARS] #2394499
10/29/17 12:33 AM
10/29/17 12:33 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Then get a pan gasket for a 98 Dakota with a 5.2 1 piece rubber gasket some rblock with the 340 mains still take a 360 pan gasket
Re: SB oil pan gasket 360 [Re: RAY1969CARS] #2395795
10/31/17 12:23 AM
10/31/17 12:23 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Be very cautious with the pan you have if you plan on running a magnum pan gasket. They will work with a milodon pan, but won’t with a moroso. The rear lip is grooved on a moroso, which pushes the magnum gasket forward or back, causing a leak. Ask me how I know...
Re: SB oil pan gasket 360 [Re: 340_Dart] #2395810
10/31/17 12:53 AM
10/31/17 12:53 AM
CA.
CA.
I'm using a la 360 pan on a la 360
Re: SB oil pan gasket 360 [Re: cudaman1969] #2396694
11/01/17 03:02 PM
11/01/17 03:02 PM
yes they do & a tip is to thread several studs into the block pan rail threads as a guide so you can set the pan straight down on the gasket WO haveing to shift it around to line up the holes which hurts the sealing.
