Shaker hood bolts #2392554
10/24/17 09:20 PM
10/24/17 09:20 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
What does the bolt look like that attaches the shaker bubble to the adapter plate? Also is the clip that holds the carb air cable the same one as under the dash for the heater cables. Thanks.
Re: Shaker hood bolts [Re: fastmark] #2392579
10/24/17 10:03 PM
10/24/17 10:03 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Here's a pic
68 Charger
70 Cuda
Re: Shaker hood bolts [Re: fastmark] #2392625
10/24/17 10:59 PM
10/24/17 10:59 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks for the picture. How about the bolt head. Does it have a captured washer?
Re: Shaker hood bolts [Re: FC7cuda] #2392629
10/24/17 11:00 PM
10/24/17 11:00 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Black phosphate bolt with captured washer...anchor on head.
Here's another bellcrank picture, original cables.
And yes,... clip is same as used on heater cables.
Re: Shaker hood bolts [Re: fastmark] #2392637
10/24/17 11:19 PM
10/24/17 11:19 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
shruggy is this it? http://www.rtspecialties.net/proddetail.asp?prod=6015143
Jim Fillmore of Detroit Muscle Technologies said he is going to have those remade soon in the OEM style olive drab color
Re: Shaker hood bolts [Re: mccannix] #2392670
10/25/17 12:14 AM
10/25/17 12:14 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Terry,
Great picture. Do you have one of the correct screw?
Thanks Ken
Re: Shaker hood bolts [Re: fastmark] #2392674
10/25/17 12:19 AM
10/25/17 12:19 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
That’s what I need guys. Thanks.
Re: Shaker hood bolts [Re: fastmark] #2392805
10/25/17 10:27 AM
10/25/17 10:27 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Terry -
I've also seen a couple cars with bubble bolts that have a "pitchfork" style marking on the head. But, I'm not sure if the bolts were original to the car or not. based on the condition of the cars, I would believe they were correct.
Have you also observed this type of head marking on the bolts? Or have all original cars you have seen have anchor head bolts?
On another note...I believe the bubble door cable clip that holds the cable to the bell-crank is phosphate, not olive drab. At least I have never seen an original Shaker car with that clip in olive drab.
Rob
Re: Shaker hood bolts [Re: fastmark] #2392821
10/25/17 11:01 AM
10/25/17 11:01 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have not seen the pitchfork bolt used but it may have been substituted.
The only for sure substitute that was used, as was told to me by a Fram employee, was an identical phosphate bolt with a P for a short period of time, because the supplier was out of the anchor bolts.
I have seen phosphate phillips screws used as well to hold the cables.
I got this stuff in a box from Fram years ago naming the 'pin' shown in earlier photo
Re: Shaker hood bolts [Re: UCUDANT] #2392894
10/25/17 02:00 PM
10/25/17 02:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Olive drab?
Never seen anything but black phosphate
Re: Shaker hood bolts [Re: gtx6970] #2393323
10/26/17 12:47 PM
10/26/17 12:47 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Pardon my lack of knowledge but what are the two cables. I know one goes to the red handle inside the car what is the other one?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Shaker hood bolts [Re: fastmark] #2393337
10/26/17 01:19 PM
10/26/17 01:19 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What are you trying to do when you pull the red handle under the dasH?
You are opening the cold air door, and closing the hot air door.
Re: Shaker hood bolts [Re: MOPARMIKE69] #2393542
10/26/17 10:01 PM
10/26/17 10:01 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
This shows where the other cable is hooked to.
Re: Shaker hood bolts [Re: fastmark] #2393694
10/27/17 07:26 AM
10/27/17 07:26 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
What is correct at the cable end on the bellcrank pins - the “push clip” that FC7cuda showed or the hairpin clips shown by maccanix’s post and box of pins?
Re: Shaker hood bolts [Re: larry4406] #2393702
10/27/17 08:44 AM
10/27/17 08:44 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
I believe that both attachment versions are original. I'm not sure which the OEM Gold judges consider correct???
Terry, have you noticed the different versions of shaker cable attachment end tabs? I've seen at least 3. The 2 in our pics and one other round hole version.
Tom
68 Charger
70 Cuda
Re: Shaker hood bolts [Re: FC7cuda] #2393747
10/27/17 11:21 AM
10/27/17 11:21 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I've only seen the hairpin clip but then I have not seen them all.
I have also seen original examples with nothing.
Plus another print shows different end tabs
Mechanics hated shaker set-ups because of the burden of removing everything to work on carb(s).
I remember one mechanic told me those kinds of things were the first to be tossed figuring the screws are holding the cable tightly.
As for the cable ends I've seen two different long cable ends, notched end and not, and then there are the two different repro versions.
As for short cable, here is an NOS one on the top verses repro.
Note the end differences and taper on the original... plus, any short originals I have seen always had the ribbing as seen in the original with script.
