440-1 Rocker arms #2392016
10/23/17 08:20 PM
10/23/17 08:20 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline OP
Hey guys seeking input here on choice of rockers for my Indy -1 heads. Torn here few good options here for sure. I really like Harland Sharps & Comp Cams. Just curious what guys ar running. Any pro's or cons & any other choices or inputs would be great
Thank you, Ken
Re: 440-1 Rocker arms [Re: 1974 474 Duster] #2392039
10/23/17 09:25 PM
10/23/17 09:25 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I'm going with Harland Sharps or T&D. I liked the idea and strength of the chromoly comp pro magnums but the max spring diameter is listed at 1.56 inches where the HS were 1.650. The springs on the Trick Flow head I am looking at are 1.56, to close for comfort for me.
Thx
Steve
Re: 440-1 Rocker arms [Re: srunge55] #2392041
10/23/17 09:36 PM
10/23/17 09:36 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Hi think I heard on Moparts that Harlan Sharp will clearance your rockers even more if you ask them to. I did mine myself sanding rolls carefully
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440-1 Rocker arms [Re: 1974 474 Duster] #2392068
10/23/17 10:19 PM
10/23/17 10:19 PM
I have used several different sets of Harland Sharp single shaft rockers on different sets 440-1 heads in 1.65 ratio up
I have one set of 440-1 that I bought used from a member on here that came with a set of Jesel pair shaft rockers in steel that are 1.55 ratio, that motor has not been ran yet so no actual live feed back, sorry.
I have never used any of Comp rockers systems either so no feed back on them.
Re: 440-1 Rocker arms [Re: 1974 474 Duster] #2393689
10/27/17 05:33 AM
10/27/17 05:33 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Does comp even offer rockers for 440-1's? I have used Ersons, Dove, TD and Harland Sharp. Ersons were great and reasonably priced, unfortunately not made anymore. Doves lasted for 2-3 years in our use, might work with a flat tappet or smallish street roller. For what ever reason, we had nothing but problems with TD, the pushrods didn't like to stay in the cups. HArland Sharps worked great, and I too clearanced them myself.
Plynouth VIP '67 TT IC EFI
Re: 440-1 Rocker arms [Re: 1974 474 Duster] #2393699
10/27/17 08:41 AM
10/27/17 08:41 AM
Yes Comp now lists an .800 offset rocker set specifically for the -1 heads.
I've always liked the quality of there products. Going to Summit tomorrow to see if they have a set in stock. Thanks, look like it will probably be Harland here as well.
Thanks, Ken
Re: 440-1 Rocker arms [Re: jyrki] #2393721
10/27/17 10:19 AM
10/27/17 10:19 AM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
T&Ds having push rods popping out of the cups...Why is this?
I know of a couple of racers having the same issues with 440-1s with single/common shaft T&Ds.
Re: 440-1 Rocker arms [Re: moparmitch] #2393734
10/27/17 10:50 AM
10/27/17 10:50 AM
PA.
"Little"John
"Little"John
PA.
Probably improperly valve lash setting. With a cup you can get away with it but to much lash with a ball ball pushrod will bite you in the butt.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 440-1 Rocker arms [Re: moparmitch] #2393833
10/27/17 03:05 PM
10/27/17 03:05 PM
I would think that the intake pushrods are rubbing on the heads forcing the pushrods out of the adjusters scope shruggy
Re: 440-1 Rocker arms [Re: Cab_Burge] #2394016
10/27/17 10:15 PM
10/27/17 10:15 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
It's possible although they did not hit, and there was absolutely no signs in the pushrods that they had rubbed anything. I do not blame the rockers, the real reason may be whatever; too little spring pressure or something else. Anyway, that's what happened and it always went in to the shaft side..., making the rocker ratio interesting. No such problems with any other rockers with the same set up. In our B1's TD's single shaft solved all the valvetrain problems.
Re: 440-1 Rocker arms [Re: jyrki] #2394027
10/27/17 10:34 PM
10/27/17 10:34 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
JYRKI - what ratio where the T&Ds you used?
This space not for rent.
Re: 440-1 Rocker arms [Re: moparmitch] #2394110
10/28/17 01:23 AM
10/28/17 01:23 AM
USA
B3RE Offline
B3RE  Offline
USA
[quote=moparmitch]T&Ds having push rods popping out of the cups...Why is this?
[4/quote]
The single shaft T&D rocker's are a compromised design, just like any other off the shelf single shaft rocker. The adjuster angles are not correct, and that causes excessive angular it in some instances. It doesn't take much for the pushrod to come out, especially if there is any instability causing valve float.
To the OP, it would be worth considering a set of the rockers shown in the pic. They are T&Ds made to my spec, and the angles are spot on when correctly installed. With a .720"ish solid roller, it had less than a .045" sweep on the valve tip. Well worth considering if you want it right.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
