69 Super Bee WM23H9A280311
#2393503
10/26/17 08:04 PM
10/26/17 08:04 PM
Posts: 54 Michigan
Mike W
Hello. I recently purchased a 1968 Super Bee with the wrong stuff in it. I am taking it back to original. Today while taking it apart I found the build sheet, and matching numbers engine and trans for a 1969 Super Bee. I also have the ramcharger hood for the car. If this is your car contact me to collect the goods. I assume the car was totaled or stripped down, but thought it was worth a shot. Thanks! Mike
Re: 69 Super Bee WM239A280311
[Re: Mike W]
#2393703
10/27/17 08:51 AM
10/27/17 08:51 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
I applaud your effort, hope it works out. BTW, you're missing the H in you VIN heading
68 Charger 70 Cuda
[Re: Mike W]
#2393725
10/27/17 10:24 AM
10/27/17 10:24 AM
Posts: 2,858 Pattison Texas
CSK
Pattison Texas
did you check the body #s ?
[Re: mattsmopars]
#2393914
10/27/17 06:26 PM
10/27/17 06:26 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I too applaud your efforts and hope they are fruitful. Unfortunately, the parts usage tend to point to a junked '69. You never know though... Stranger things have happened but... It makes much more sense to me, to replace seats and a motor/trans and other bolt on parts from a parts car, than to replace the hood, front fenders, grill, core support sheet metal, rear 1/4 panels/side marker lite openings, tail panel & tail lites, for a fraudulent cause.
I have mechanical Aptitude. I can screw up anything.
[Re: RTSrunner]
#2394299
10/28/17 05:37 PM
10/28/17 05:37 PM
Posts: 54 Michigan
Mike W
So,if I am reading correctly the '68 you are restoring is a Hemi car,correct? RT Yes it is. It is going to be a bit of a challenging project, but hopefully a fun car. I got it out of Pennsylvania. Hoping to track down the original engine someday, but I realize this is most improbable.
Re: 69 Super Bee WM23H9A280311
[Re: Mike W]
#2394655
10/29/17 09:41 AM
10/29/17 09:41 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
I do not have any record of this car. The assumption the 69 is long gone is mostly likely correct.
Can you post the EAD and casting dates from the block for us numbers junkies? Thank you.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
