Which electric pump for street with a carb
#2393359
10/26/17 02:02 PM
10/26/17 02:02 PM
Posts: 1,505 TN
SCATPACK 1
TN
I am currently using a mechanical Hemi pump that has been modified to produce a steady 7 pound of pressure. have been experiencing some issues lately with the sorry gas with ethanol affecting the rubber bladders in mechanical pumps. I try to use 100% Gas when I can find it but it limits my traveling and long cruises some. What electric pump are you guys using that is reliable on long runs and not so noisy or too loud to interfere with enjoying radio. I have had Holley's twice and they do not seem to last very long for me. Using a Carb and not fuel injection and I do not have ability to put a pump inside my tank.
Old Geezer Racing
Re: Which electric pump for street with a carb
[Re: SCATPACK 1]
#2393370
10/26/17 02:28 PM
10/26/17 02:28 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
You can never have a pump too large.I use a Magna 500 with built in filter. Noise depends how you mount it.
[Re: hemi-itis]
#2393371
10/26/17 02:32 PM
10/26/17 02:32 PM
Posts: 1,505 TN
SCATPACK 1
TN
Do you have a picture of yours mounted on your Cuda
Old Geezer Racing
[Re: SCATPACK 1]
#2393374
10/26/17 02:37 PM
10/26/17 02:37 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Aeromotive 11203
And actually i have never had a single problem with a Holley black either, including on 9 sec type car.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: SCATPACK 1]
#2393383
10/26/17 02:55 PM
10/26/17 02:55 PM
Posts: 860 lancaster,california
johnnycuda
Carter electric pumps are quieter than the Holley, and last a long time, #P4070 is a 7lbs pump, requires no regulator, around 70GPH, have one on my driver Barracuda, I have the Holley black pump on my '70 'Cuda, street/strip car for about 10 years so far.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Thumperdart]
#2393438
10/26/17 04:55 PM
10/26/17 04:55 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Mallory 140 since 03, i did just put a rebuild kit in it this year
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2393442
10/26/17 05:10 PM
10/26/17 05:10 PM
Posts: 784 Liverpool, NY
SILVER67
Liverpool, NY
Mallory 140 since 03, i did just put a rebuild kit in it this year Mallory 140 since 2012 Over 5,000 miles and 50+ passes
[Re: SCATPACK 1]
#2393450
10/26/17 05:28 PM
10/26/17 05:28 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Using a Carter pump on mine with zero problems.
[Re: SCATPACK 1]
#2393484
10/26/17 07:12 PM
10/26/17 07:12 PM
Posts: 1,505 TN
SCATPACK 1
TN
Thanks for the answers guys. Gives me some ideas
Old Geezer Racing
[Re: SCATPACK 1]
#2393492
10/26/17 07:30 PM
10/26/17 07:30 PM
Posts: 16,493 On the run…
BloFish
On the run…
Another satisfied Aeromotive customer here.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: SCATPACK 1]
#2393531
10/26/17 09:24 PM
10/26/17 09:24 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
How about 2 pumps? I use a Carter mech pump on the Cuda for street driving. But it won't feed the Dominator through the gears at the track.
So I installed a Holley pump back by the tank with a micro switch on the carb that is actuated by the lever on the carb's secondaries. I also have a manual override switch under the dash, just in case.
The mech pump pulls through the electric just fine. The electric lasts forever with only intermittent use and I don't have to listen to it running all the time.
I have used this kind of combo on several different cars over the last 30 years or so with no problems.
Master, again and still
[Re: SCATPACK 1]
#2393618
10/27/17 12:24 AM
10/27/17 12:24 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Similar to DaveRS23 above..... I added an electric pump last year, using the Carter 4600HP rotary vane pump. My car still sees a decent amount of street miles, so I kept the mechanical pump (Carter 6903) and added the electric in series and on a switch. I also ran a bypass line around the electric pump with a one-way check valve, so the mechanical sucks just fine around the electric, then when needed I can switch on the electric. After a season of use, I’d say it works perfectly and was a worthwhile upgrade. The micro switch on the carb is a great idea. I just switch mine on prior to staging as part of my routine at the same time I arm the 2-step.
[Re: DaveRS23]
#2393623
10/27/17 12:29 AM
10/27/17 12:29 AM
Posts: 1,505 TN
SCATPACK 1
TN
I have used this kind of combo on several different cars over the last 30 years or so with no problems. Dave That is exactly how I have my car set up. mechanical pump on the motor and Holley Red pump at the rear. Holley is wired to an on off switch. But I don't trust the Holley if the manual pump bladder goes out on a long trip. Maybe I am worrying over nothing. Really Good idea about the micro switch for the electric pump trigger.
Old Geezer Racing
[Re: SILVER67]
#2393708
10/27/17 09:41 AM
10/27/17 09:41 AM
BradH
Mallory 140 since 03, i did just put a rebuild kit in it this year Mallory 140 since 2012 Over 5,000 miles and 50+ passes Another Mallory (now owned by MSD) 140 user here. However, their price has gone up so much over the years since I first bought one that it makes sense to see what else is available that has proven reliability.
[Re: SCATPACK 1]
#2393769
10/27/17 12:31 PM
10/27/17 12:31 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I put lots of mile and lots of years on a Holley Blue pump with zero trouble, I only changed it because I went to fuel injection.
68 Barracuda Formula S 340
[Re: SCATPACK 1]
#2393778
10/27/17 12:36 PM
10/27/17 12:36 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
After 2 MagnaFuel failures, I switched to a Weldon and never looked back.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
