Which electric pump for street with a carb #2393359
10/26/17 02:02 PM
10/26/17 02:02 PM
TN
SCATPACK 1 Offline OP
TN
I am currently using a mechanical Hemi pump that has been modified to produce a steady 7 pound of pressure. have been experiencing some issues lately with the sorry gas with ethanol affecting the rubber bladders in mechanical pumps. I try to use 100% Gas when I can find it but it limits my traveling and long cruises some.
What electric pump are you guys using that is reliable on long runs and not so noisy or too loud to interfere with enjoying radio.
I have had Holley's twice and they do not seem to last very long for me.
Using a Carb and not fuel injection and I do not have ability to put a pump inside my tank.
Old Geezer Racing
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393370
10/26/17 02:28 PM
10/26/17 02:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can never have a pump too large.I use a Magna 500 with built in filter. Noise depends how you mount it.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Which electric pump for street with a carb [Re: hemi-itis] #2393371
10/26/17 02:32 PM
10/26/17 02:32 PM
TN
TN
Do you have a picture of yours mounted on your Cuda
Old Geezer Racing
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393374
10/26/17 02:37 PM
10/26/17 02:37 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Aeromotive 11203
And actually i have never had a single problem with a Holley black either, including on 9 sec type car.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393383
10/26/17 02:55 PM
10/26/17 02:55 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Carter electric pumps are quieter than the Holley, and last a long time, #P4070 is a 7lbs pump, requires no regulator, around 70GPH, have one on my driver Barracuda, I have the Holley black pump on my '70 'Cuda, street/strip car for about 10 years so far.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393434
10/26/17 04:52 PM
10/26/17 04:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Magnafuel 300 here............. thumbs
Re: Which electric pump for street with a carb [Re: Thumperdart] #2393438
10/26/17 04:55 PM
10/26/17 04:55 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Mallory 140 since 03, i did just put a rebuild kit in it this year
Re: Which electric pump for street with a carb [Re: sixpackgut] #2393442
10/26/17 05:10 PM
10/26/17 05:10 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Mallory 140 since 2012
Over 5,000 miles and 50+ passes
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393448
10/26/17 05:25 PM
10/26/17 05:25 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Holley pump at Summit These are ultra quiet.
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393450
10/26/17 05:28 PM
10/26/17 05:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Using a Carter pump on mine with zero problems.
Nautilus Racing-
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393484
10/26/17 07:12 PM
10/26/17 07:12 PM
TN
TN
Thanks for the answers guys. Gives me some ideas
Old Geezer Racing
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393492
10/26/17 07:30 PM
10/26/17 07:30 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Another satisfied Aeromotive customer here.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393531
10/26/17 09:24 PM
10/26/17 09:24 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
How about 2 pumps? I use a Carter mech pump on the Cuda for street driving. But it won't feed the Dominator through the gears at the track.
So I installed a Holley pump back by the tank with a micro switch on the carb that is actuated by the lever on the carb's secondaries. I also have a manual override switch under the dash, just in case.
The mech pump pulls through the electric just fine. The electric lasts forever with only intermittent use and I don't have to listen to it running all the time.
I have used this kind of combo on several different cars over the last 30 years or so with no problems.
Master, again and still
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393618
10/27/17 12:24 AM
10/27/17 12:24 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Similar to DaveRS23 above..... I added an electric pump last year, using the Carter 4600HP rotary vane pump. My car still sees a decent amount of street miles, so I kept the mechanical pump (Carter 6903) and added the electric in series and on a switch. I also ran a bypass line around the electric pump with a one-way check valve, so the mechanical sucks just fine around the electric, then when needed I can switch on the electric. After a season of use, I’d say it works perfectly and was a worthwhile upgrade. The micro switch on the carb is a great idea. I just switch mine on prior to staging as part of my routine at the same time I arm the 2-step.
Re: Which electric pump for street with a carb [Re: DaveRS23] #2393623
10/27/17 12:29 AM
10/27/17 12:29 AM
TN
TN
That is exactly how I have my car set up. mechanical pump on the motor and Holley Red pump at the rear. Holley is wired to an on off switch. But I don't trust the Holley if the manual pump bladder goes out on a long trip. Maybe I am worrying over nothing.
Really Good idea about the micro switch for the electric pump trigger.
Old Geezer Racing
Re: Which electric pump for street with a carb [Re: SILVER67] #2393708
10/27/17 09:41 AM
10/27/17 09:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Another Mallory (now owned by MSD) 140 user here.
However, their price has gone up so much over the years since I first bought one that it makes sense to see what else is available that has proven reliability.
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393769
10/27/17 12:31 PM
10/27/17 12:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I put lots of mile and lots of years on a Holley Blue pump with zero trouble, I only changed it because I went to fuel injection.
68 Barracuda Formula S 340
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393773
10/27/17 12:34 PM
10/27/17 12:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I vote for the Carter. (It's a Mopar thing.)
2011 Drag Pak Challenger
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393777
10/27/17 12:36 PM
10/27/17 12:36 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
Is anybody running an efi pump with a carb? I hear it works well if you use the proper bypass regulator. The in tank Walbro pumps are cheap and supposed to be reliable and I like the idea of in-tank because its quieter and runs cooler.
Re: Which electric pump for street with a carb [Re: SCATPACK 1] #2393778
10/27/17 12:36 PM
10/27/17 12:36 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
After 2 MagnaFuel failures, I switched to a Weldon and never looked back.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
