Where to find replacement captive studs on exterior trim?
#2392089
10/23/17 11:28 PM
10/23/17 11:28 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
Anyone know if there are replacement studs available for parts that were captive on exterior trim parts? This part is the quarter/tail panel extension on a 70 Dart (LH and RH).
I'm also looking for a robust procedure for removing the stud. My initial thoughts were to trim the damaged studs down and then drill the stud out followed by tapping the molded stanchion and use of some adhesive.
Re: Where to find replacement captive studs on exterior trim?
[Re: polaraholic]
#2392123
10/24/17 12:29 AM
10/24/17 12:29 AM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
E-Bay Look under trim nuts. got a link?? i have never seen the studs available..
[Re: vinnyd76]
#2392190
10/24/17 03:16 AM
10/24/17 03:16 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I'm also looking for a robust procedure for removing the stud. My initial thoughts were to trim the damaged studs down and then drill the stud out followed by tapping the molded stanchion and use of some adhesive. I did this on my 68 Charger ,similar set up, I ground off the broken stud,drilled & tapped for a stud.
[Re: CSK]
#2392232
10/24/17 10:39 AM
10/24/17 10:39 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I'm also looking for a robust procedure for removing the stud. My initial thoughts were to trim the damaged studs down and then drill the stud out followed by tapping the molded stanchion and use of some adhesive. I did this on my 68 Charger ,similar set up, I ground off the broken stud,drilled & tapped for a stud. Did same thing on my 72 Dart front fender extensions way back when.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2392582
10/24/17 10:07 PM
10/24/17 10:07 PM
vinnyd76
Macomb, MI
Finished product after obtaining some very good experience at work today. No cracks in the stanchions either.
Thank you for the feedback on the how to repair.
[Re: vinnyd76]
#2392785
10/25/17 09:25 AM
10/25/17 09:25 AM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
What material did you use?
[Re: markz528]
#2393437
10/26/17 04:54 PM
10/26/17 04:54 PM
vinnyd76
Macomb, MI
What material did you use? We used a 1/4-20 Grade-8 bolt and trimmed it down to roughly an 1.5" length. The bolt tip was sanded to a point to match the other three.
