Neutral safety switch #2391580
10/23/17 01:20 AM
10/23/17 01:20 AM
CA.
RAY1969CARS Offline OP
CA.
Hi guys I have a B & m automatic shifter and was looking at the yellow wire coming off of the starter that go to the ignition and was wondering if that's where I splice into I have a stock wiring harness 1969 dart
Re: Neutral safety switch [Re: RAY1969CARS] #2391613
10/23/17 03:20 AM
10/23/17 03:20 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Not sure what you want the shifter to do?
Re: Neutral safety switch [Re: RAY1969CARS] #2391615
10/23/17 03:22 AM
10/23/17 03:22 AM
Are you wanting to bypass the stock neutral safety switch in the tranny and use the one on the new shifter? If so, why confused shruggy
If you leave all the stock parts in place, neutral safety switch in the tranny and the stock starter relay on the fenderwell or firewall and change the shifter only it will still work like stock up scope
Re: Neutral safety switch [Re: Cab_Burge] #2391838
10/23/17 03:07 PM
10/23/17 03:07 PM
CA.
CA.
I'm not using the stock wine harness that goes to the transmission
Re: Neutral safety switch [Re: RAY1969CARS] #2391923
10/23/17 05:13 PM
10/23/17 05:13 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Do you have a stock starter relay? If so, make the shifter supply ground to the brown wire on there. It is marked with a "G" and is sometimes hard to see because the brown wire's terminal has rubber around it. No power required. Attach the shifter's neutral safety switch to ground and run the other side to that brown wire's terminal. up
Re: Neutral safety switch [Re: RAY1969CARS] #2391925
10/23/17 05:16 PM
10/23/17 05:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What transmission? If it is a 727/904 then its pretty simple.
Re: Neutral safety switch [Re: RAY1969CARS] #2392049
10/23/17 09:52 PM
10/23/17 09:52 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I prefer to use the original setup. The plug is around $30 new. Going that way keeps the wiring easy and in the engine compartment so routing into and out of the interior is eliminated. Also, while they may be very reliable, the shifter supplied mini-micro switches always gave me an uneasy feeling.
Like Dave Hall said, you are switching a ground, not battery. Just extend the middle brown lead to the "G" terminal and you're ready to go.
Re: Neutral safety switch [Re: shorthorse] #2392094
10/23/17 11:36 PM
10/23/17 11:36 PM
CA.
CA.
I've reading online that some officials are saying it cannot start in neutral is this true
B&M mega shifter. 69 dart
Local tracks Irwindale Fontana Bakersfield and Pomona
And thanks short Horse worked great
Re: Neutral safety switch [Re: RAY1969CARS] #2392152
10/24/17 01:50 AM
10/24/17 01:50 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It can start in "P" or "N" only. I have mine wired so that it will only start in park, or slightly south of there. whistling Kind of a pain. It will make you pay attention though.
Re: Neutral safety switch [Re: RAY1969CARS] #2392155
10/24/17 01:57 AM
10/24/17 01:57 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
The only thing the rule book says is "functional neutral safety switch mandatory". Doesn't say park switch. They just want the thing to not take off when you start it. Anyone who says park only is making it up. I seem to recall when I had mine checked, they just wanted to see it not start in any gear position.
As said, if using a stock deal replace or run the wire from the "G" terminal to ground through the neutral switch on the shifter.
Re: Neutral safety switch [Re: RAY1969CARS] #2392441
10/24/17 05:42 PM
10/24/17 05:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By RAY1969CARS
I'm not using the stock wine (sic) harness that goes to the transmission
In that case just run the yellow starter wire through the B&M switch.
Re: Neutral safety switch [Re: RAY1969CARS] #2392477
10/24/17 06:55 PM
10/24/17 06:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What John said if its a TF or using stock wiring..
Re: Neutral safety switch [Re: John_Kunkel] #2392666
10/25/17 12:00 AM
10/25/17 12:00 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you do that, the G terminal (brown wire) will need to be attached to a ground to make the solenoid work.
Re: Neutral safety switch [Re: RAY1969CARS] #2392750
10/25/17 03:21 AM
10/25/17 03:21 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Why not send the ground? No brainer... Of course this all depends on the factory style starter solenoid which I don't believe has been confirmed.
Re: Neutral safety switch [Re: CMcAllister] #2392971
10/25/17 04:52 PM
10/25/17 04:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IF he's using the stock relay. Sounds like he wants to run the Start wire directly to the starter solenoid.
