Neutral safety switch
#2391580
10/23/17 01:20 AM
10/23/17 01:20 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Hi guys I have a B & m automatic shifter and was looking at the yellow wire coming off of the starter that go to the ignition and was wondering if that's where I splice into I have a stock wiring harness 1969 dart
Re: Neutral safety switch
[Re: RAY1969CARS]
#2391615
10/23/17 03:22 AM
10/23/17 03:22 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
[Re: RAY1969CARS]
#2391925
10/23/17 05:16 PM
10/23/17 05:16 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
What transmission? If it is a 727/904 then its pretty simple.
[Re: shorthorse]
#2392094
10/23/17 11:36 PM
10/23/17 11:36 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I've reading online that some officials are saying it cannot start in neutral is this true
B&M mega shifter. 69 dart Local tracks Irwindale Fontana Bakersfield and Pomona
And thanks short Horse worked great
[Re: RAY1969CARS]
#2392155
10/24/17 01:57 AM
10/24/17 01:57 AM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The only thing the rule book says is "functional neutral safety switch mandatory". Doesn't say park switch. They just want the thing to not take off when you start it. Anyone who says park only is making it up. I seem to recall when I had mine checked, they just wanted to see it not start in any gear position.
As said, if using a stock deal replace or run the wire from the "G" terminal to ground through the neutral switch on the shifter.
[Re: RAY1969CARS]
#2392441
10/24/17 05:42 PM
10/24/17 05:42 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm not using the stock wine (sic) harness that goes to the transmission In that case just run the yellow starter wire through the B&M switch.
[Re: RAY1969CARS]
#2392477
10/24/17 06:55 PM
10/24/17 06:55 PM
Al_Alguire
Las Vegas
What John said if its a TF or using stock wiring..
[Re: John_Kunkel]
#2392666
10/25/17 12:00 AM
10/25/17 12:00 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm not using the stock wine (sic) harness that goes to the transmission In that case just run the yellow starter wire through the B&M switch. If you do that, the G terminal (brown wire) will need to be attached to a ground to make the solenoid work.
[Re: CMcAllister]
#2392971
10/25/17 04:52 PM
10/25/17 04:52 PM
John_Kunkel
Rio Linda, CA
I'm not using the stock wine (sic) harness that goes to the transmission In that case just run the yellow starter wire through the B&M switch. If you do that, the G terminal (brown wire) will need to be attached to a ground to make the solenoid work. IF he's using the stock relay. Sounds like he wants to run the Start wire directly to the starter solenoid.
