Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391020
10/22/17 12:09 AM
10/22/17 12:09 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Ok who are the suppliers for the drum and valve bodies needed, I did a quick search and came back with zip.
Have a great day
Iowan
"obsolete is neat"
Re: 727 explosion at Milan last night.... [Re: Iowan] #2391026
10/22/17 12:32 AM
10/22/17 12:32 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Ascertain the performance required, select the trans and get out the credit card. There is no free lunch. They all have issues and their associated costs.
Re: 727 explosion at Milan last night.... [Re: Tempest] #2391032
10/22/17 12:46 AM
10/22/17 12:46 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Originally Posted By Tempest
Asking this question again for clarification. If one does not have an aftermarket drum and LBA, will launching car in 2nd avoid (for the most part) this issue?
I suppose it would, but you generally need first gear in drag racing. Since it’s generally when you freewheel the trans in 1st without the band applied that the drum is at risk, Most do their burnout starting in second to avoid the issue.
Re: 727 explosion at Milan last night.... [Re: Leigh] #2391033
10/22/17 12:52 AM
10/22/17 12:52 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've been running the same trans since 1988, all Turbo Action parts including the valve body. No rebuilds just maintenance, 1.40 60ft times no trans brake.
I'm just looking for the suppliers for the parts.
Have a great day
Iowan
"obsolete is neat"
Re: 727 explosion at Milan last night.... [Re: Iowan] #2391040
10/22/17 01:10 AM
10/22/17 01:10 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I bought my 727 from CRT. Building the trans is one of the few things I don't do on my cars . He sells the parts as well.
http://coperacingtrans.com/
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 727 explosion at Milan last night.... [Re: Iowan] #2391044
10/22/17 01:43 AM
10/22/17 01:43 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Call Keith Long/ 727specialists. 219/718-3542
Re: 727 explosion at Milan last night.... [Re: d7cook] #2391065
10/22/17 03:04 AM
10/22/17 03:04 AM
PA
Scully Offline
Scully  Offline
PA
Originally Posted By d7cook
It's kind of funny a year ago I posted the question about using a turbo 400 behind my big block and was told to stick with the 727 even by Monty.
GM Trannies explode too IF they are not built right or are abused. Any trans can be a time bomb if abused with the wrong parts.
Th400 main problem is tossing into nuetral across the stripe. Unless you have a valve body deigned to do it. 123n. I currently run one. Easy to build. BOP versions are cheap and plentiful. Personally I have always hated the 2-3 shift on 727's and tweaking the band.
The 2-3 shift is all about timing to avoid overlap and you can find the sweet spot by understanding the front clutch clearance, springs and the kickdown lever ratio and adjustment. The 4.2 lever is the best all around IMO, the rest comes from experience but a good 727 trans guy should know this.
Re: 727 explosion at Milan last night.... [Re: Iowan] #2391071
10/22/17 04:02 AM
10/22/17 04:02 AM
CRT, Pro Trans, ATI,T/A,A&A and a lot of others scope
Three choices on the front drum beside stock, aluminum, alunimum with a steel liner and all steel up
Re: 727 explosion at Milan last night.... [Re: slantzilla] #2391162
10/22/17 12:15 PM
10/22/17 12:15 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Keith knows a thing or two about transmissions. Bought my aluminum drum from him as well as some other parts. I like Copes rmv bodies with rear band apply.
Re: 727 explosion at Milan last night.... [Re: mopar dave] #2391234
10/22/17 02:24 PM
10/22/17 02:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I wonder about these new vb'd lba and if they were ever test on a bench or dyno to verify there correct function.[delay in shift 1 to 2 correctly.cause effect]
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391240
10/22/17 02:32 PM
10/22/17 02:32 PM
P
Porter67 Offline
Porter67  Offline
P
Are you meaning copes brand or that type VB overall?
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391253
10/22/17 02:52 PM
10/22/17 02:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it has a good drum it doesn't matter if the low roller gives up the ghost or not. I've seen low rollers break with low band apply. I have also seen Super Sprag's break.
Doug
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391262
10/22/17 03:02 PM
10/22/17 03:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it has a good drum it doesn't matter if the low roller gives up the ghost or not. I've seen low rollers break with low band apply. I have also seen Super Sprag's break. As long as the drum stays intact the worst thing you'll have is a broken , but intact trans.
Doug
Re: 727 explosion at Milan last night.... [Re: dvw] #2391264
10/22/17 03:04 PM
10/22/17 03:04 PM
Doug
iagree up bow
I was going to say the same thing last night and didn't, shame on me tsk
It is the stock cast iron front drum that explodes, not the rear roller clucth or valve body work shruggy
Re: 727 explosion at Milan last night.... [Re: dvw] #2391277
10/22/17 03:21 PM
10/22/17 03:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
so why would anyone pay more for the super sprag if they break too? save your money and just install a bolt in stock type then and use an aftermarket drum.
Re: 727 explosion at Milan last night.... [Re: Porter67] #2391289
10/22/17 03:44 PM
10/22/17 03:44 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Any brand,The racers seem to be the test bed for a new product to work out the bug most of the time.
Re: 727 explosion at Milan last night.... [Re: mopar dave] #2391290
10/22/17 03:45 PM
10/22/17 03:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's what I did.
Re: 727 explosion at Milan last night.... [Re: Scully] #2391295
10/22/17 03:58 PM
10/22/17 03:58 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Ironically one way to make a th400 bullet prof is to go sprag less which I think griner developed the vb for but...... The 2-3 shift becomes about timing to avoid overlap.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: 727 explosion at Milan last night.... [Re: justinp61] #2391297
10/22/17 04:00 PM
10/22/17 04:00 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Did anyone ever check to see if ATI makes a 727 aftermarket case. My ATI
Case is very heavy duty and comes with a steel safety liner that slides down into the pump
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 explosion at Milan last night.... [Re: Clanton] #2391301
10/22/17 04:04 PM
10/22/17 04:04 PM
P
Porter67 Offline
Porter67  Offline
P
Ive an aa or aaa? I think cope uses his own now? And ive never noticed a delay at the track or street when hooked, if im horsing around and blow the drag radials off I can hear the 1-2 shift in the motor but its not enough to make the tach needle drop, by then im already in 2nd at 7200, about a second and a half but I always run it out when I do and it gently hooks, I never let off abruptly.
Do the data loggers show the delay?
