any difference between a 67 and 68 -440 intake #2390951
10/21/17 08:32 PM
10/21/17 08:32 PM
British Columbia
Y
yellowgtx Offline OP
Y
British Columbia
I hope to some day get a 2X4 intake but cant afford it right now. I have a 69 440 30 over going together with 6 Pack new pistons. I also have a 67 and 68 440 intake which one is better for now or are they the same
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2390953
10/21/17 08:33 PM
10/21/17 08:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
they should be the same casting number, just different dates
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2390966
10/21/17 09:24 PM
10/21/17 09:24 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thought he 67 was the low one. 68 being the first for the 906 head
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2390967
10/21/17 09:27 PM
10/21/17 09:27 PM
Does the 1967 intake have the small AFB carb. bolt pattern or the larger AVS pattern? scope I think some of the Chrysler non HP 440 C body engines came with Holley carbs also confused
Re: any difference between a 67 and 68 -440 intake [Re: Cab_Burge] #2390970
10/21/17 09:37 PM
10/21/17 09:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Yes: The 67 has the small AFB, 68 has the larger AVS. I thought the manifolds were different however everywhere lists the same casting #.
Sheldon
Re: any difference between a 67 and 68 -440 intake [Re: RUNCHARGER] #2390981
10/21/17 10:02 PM
10/21/17 10:02 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Does the number end in 187?
Re: any difference between a 67 and 68 -440 intake [Re: RUNCHARGER] #2390984
10/21/17 10:13 PM
10/21/17 10:13 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1966 Parts Catalog:
9-48-7 440 #1858623
1967 Parts Catalog:
9-48-7 440 #2843031
1968 Parts Catalog:
9-48-7 440 #2843031
per GG's "white book" 440 4bbl intake manifolds:
1966 cast #2206000 (part #1858623)
1967 cast #2806178 (part #2843031)
1968 cast #2806178 (part #2843031)
1969 cast #2806178 (part #2843031)
per HOLLANDER 42nd edition:
1966 *264 - #1858623 interchangeable '59-'66 413/440
1967 *492 - #2806178 all Chrysler Corp 440 4bbl '67-'69
1968 *492
1969 *492
1966 thru 1969 intakes shown below, anyone have a pic of a "flat" 440 intake with a July '66 or later casting date on it?
1966 440 intake.jpg1967 440 intake.jpg1968 440 intake.jpg1969 440 intake.jpg
Re: any difference between a 67 and 68 -440 intake [Re: pushbutton] #2390999
10/21/17 11:00 PM
10/21/17 11:00 PM
British Columbia
Y
Y
British Columbia
Both have the same casting Number. 2806178 but I was just going by the stamping date. the 67 is 5-67 the 68 is 12-17-68. I will have to go to shop tomorrow as the 68 has some kind of weird carb and plate on it. I will pop it off . The 67 seems to have small intake holes in it.
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2391021
10/22/17 12:11 AM
10/22/17 12:11 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Same casting number, same intake. The 375 hp rated 440s from 67 have the 178 intake. The 350 hp 440s might have the lower manifold, as someone suggested.
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2391038
10/22/17 01:05 AM
10/22/17 01:05 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
ALL 440's from 1967 through 1969 model years had the same intake manifold. Just bolt On the carb, choke, and vacuum fitting for your car.
The small mouth AFB from the 375 horse 440 engine has the wide bolt pattern on it. The 1967 383 small mouth AFB has the narrow bolt pattern. This might cause some confusion.
Yes the 350 horse C body had holleys, but the intake is not different.
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2391089
10/22/17 09:42 AM
10/22/17 09:42 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Don't confuse casting number with part number. A casting can be machined into many different part numbers.
Re: any difference between a 67 and 68 -440 intake [Re: TooMany62s] #2391255
10/22/17 02:52 PM
10/22/17 02:52 PM
RUNCHARGER Offline
RUNCHARGER  Offline
That's what I was wondering too. Those 67 carbs had small throttle bores I believe.
Sheldon
Re: any difference between a 67 and 68 -440 intake [Re: yellowgtx] #2391319
10/22/17 04:37 PM
10/22/17 04:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Let's not try to make this harder than it really is.
The intakes are the same on 1967-1969 440 engines. 2806178
There's really nothing more to say about it.
1967 440 magnum carbs have 1 11/16 throttle plates, all 4 the same size.
Remember the good old days when you could buy a full size 440 Mopar for $300 and drive it? Well the first thing to do was toss the junk factory Holley and put on a 440 HP AVs carb and they always bolt right on to the intake.
Re: any difference between a 67 and 68 -440 intake [Re: RUNCHARGER] #2391425
10/22/17 08:43 PM
10/22/17 08:43 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
No.
Re: any difference between a 67 and 68 -440 intake [Re: BSB67] #2391675
10/23/17 10:50 AM
10/23/17 10:50 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
No.
The AFB carbs have smaller bases, the AVS carbs have a larger base ( where the air filter sits).....
Re: any difference between a 67 and 68 -440 intake [Re: floridian] #2392125
10/24/17 12:31 AM
10/24/17 12:31 AM
British Columbia
Y
Y
British Columbia
Ok since I started this I just went out and took of the carb that was on the 68 Manifold with a spacer plate. (unknown what the heck it is) Both the 67and 68 side by side have Same casting numbers all 8 bores 1-11/16". The only difference I could see was the casting dates. My 625 Carter AFB comp series fit on both and carb plates opened up on manifolds.
Originally I was just wondering if there was any performance difference, but I guess we answered that now.
I do thank you for all the replies.
