Speedmaster SB roller rockers any good? #2389735
10/19/17 10:48 AM
10/19/17 10:48 AM
Ohio
moparjoe360.4 Offline OP
Ohio
I'm looking into getting roller rockers for a 410 stroker I'm building, I really want Harland Shaps but can't swing the $700 right now. I found what I think is a good deal on a set of Speedmasters, but it's the first time I've heard of them so I don't know if I should pull the trigger or save the $$$ for a set of Harland Sharps. Another question I have is will I need new push rods with them. I'm on a tight budget and the original plan was to reuse the stock stamped rockers and push rods. I have a .508/ 292 purpleshaft for it already and it's just a street/strip deal. Any advice is greatly appreciated!
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2389769
10/19/17 12:11 PM
10/19/17 12:11 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Before i bought that stuff i would probably look around for a set of 273 adjustable rockers.
Usually can find them easily and cheap.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Speedmaster SB roller rockers any good? [Re: B3422W5] #2390061
10/19/17 10:45 PM
10/19/17 10:45 PM
Ohio
Ohio
That's a pretty good idea, what sucks is my dad and I have scrapped multiple sets of those rockers over the years because they got wet in floods. I'm guessing the Speedmasters are cheep import junk from the price point, that's why I asked. I can get my hands on a set complete with hold downs for under $200.
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390070
10/19/17 11:01 PM
10/19/17 11:01 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
A friend of mine broke one (Promaster) on an NHRA Stock Eliminator SBM, I would stay away.
Bill
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390197
10/20/17 07:28 AM
10/20/17 07:28 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
http://www.manciniracing.com/maraenadroar.html
These are not Crane or Isky brand but the design is very reliable.
Keep old mopars alive.
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390199
10/20/17 08:44 AM
10/20/17 08:44 AM
Ohio
Ohio
Thanks those look like a nice set up. Here's a link to the Speedmasters. http://www.jegs.com/i/Speedmaster/746/PCE261.1031/10002/-1
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390200
10/20/17 08:48 AM
10/20/17 08:48 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Most adjustable rockers use ball and cup pushrods, so yes, you will need new pushrods. At .500" lift, you are not stressing the valvetrain, so those rockers will probably work for now. But as your engine develops, the demands will become higher, and you will be needing different rockers. H/S are so popular, with a little searching, you can find a used set with shafts for the right price.
[image][/image]
Re: Speedmaster SB roller rockers any good? [Re: 2boltmain] #2390286
10/20/17 01:56 PM
10/20/17 01:56 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Who is casting iron rockers cheap enough to sell for that price? Wonder if they are a refurbished 273 rockers with new hardware?
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390306
10/20/17 02:51 PM
10/20/17 02:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My default "budget" rockers are the Mancini HS variety.
I think they're under $500 for rockers, spacers, shafts.
I'm not in the "Chinese rockers" camp.
I'd use the original ones on a 292 cam before I ran $200 offshore stuff.
Re: Speedmaster SB roller rockers any good? [Re: fast68plymouth] #2390379
10/20/17 06:00 PM
10/20/17 06:00 PM
Ohio
Ohio
That's the kind of Info I was looking for. It's the way I've always swayed but the price tempted me this time for some reason.
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390382
10/20/17 06:09 PM
10/20/17 06:09 PM
P
Porter67 Offline
Porter67  Offline
P
Oem rockers wont work well with oem pushrods, the length is off, youd need to buy pushrods. The 484/284 mopar cam just barely works with all oem parts.
Many have used the prw SS rockers with good results but they have jumped up alot in price, like over $400.
Re: Speedmaster SB roller rockers any good? [Re: moparjoe360.4] #2390547
10/20/17 10:36 PM
10/20/17 10:36 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I shy away from that import stuff... they might look good but often don't perform very good. You get what you pay for...
Re: Speedmaster SB roller rockers any good? [Re: Medlock51] #2390570
10/20/17 11:08 PM
10/20/17 11:08 PM
P
Porter67 Offline
Porter67  Offline
P
So what brand crank and rods do you use?
