Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390258
10/20/17 12:29 PM
10/20/17 12:29 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I looked at a new to the market SFI approved blanket being offered last week - covers the whole transmission including the bell housing - its being made specifically for the TF727 and is very well designed using ballistic grade fabrics - seeing these explosions reminds me - better safe than sorry!
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390259
10/20/17 12:31 PM
10/20/17 12:31 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
It was rough. He had a blanket, but everything was mangled. Overhearing the guys talk, it broke the block, bent the framerail, bent the headers. You could see the floorpan bent well past the gas pedal mount.
Insult to injury, as was mentioned, the car was pushed back over the shrapnel which cut the slick.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390262
10/20/17 12:46 PM
10/20/17 12:46 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks for all the updates, sorry for all the damage, but glad all he had was a cut.
Bill
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390274
10/20/17 01:33 PM
10/20/17 01:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
So what failed, the roller clutch allowing the drum to burst or the converter?
ETA...NVM, now that I see the pictures.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390283
10/20/17 01:46 PM
10/20/17 01:46 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
A few pics. In the 2nd pic you can see the sun sheet is expanded on the edge. That's where the high gear drum sets.
Doug
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390285
10/20/17 01:55 PM
10/20/17 01:55 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
was he running a stock drum with a trans brake? - sure looks like that converter ballooned up. Glad he walked away that could have been real ugly..
Re: 727 explosion at Milan last night.... [Re: DoubleD] #2390301
10/20/17 02:34 PM
10/20/17 02:34 PM
fullmetaljacket Offline
Pretty violent.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390307
10/20/17 02:54 PM
10/20/17 02:54 PM
crlush Offline
crlush  Offline
eek eek eek glad hes ok, saw it happen at ubly once on a stock looking road runner, a girl was driving it and it let loose doing a burnout, she broke her foot and was back later wearing a cast.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390319
10/20/17 03:23 PM
10/20/17 03:23 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Stock Drum...?
Sorta looks like on.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390331
10/20/17 03:56 PM
10/20/17 03:56 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That's ugly!!
Pretty serious carnage to that floor pan.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390370
10/20/17 05:44 PM
10/20/17 05:44 PM
P
Porter67 Offline
Porter67  Offline
P
Thats the worst ive seen, glad the guy is ok for sure.
I cant imagine being that close to that happening.
What converter is that?
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390408
10/20/17 06:49 PM
10/20/17 06:49 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
First pic flame in scoop.
Second pic, smoke plume coming from hoodside on drivers side.
I wonder if more mayhem has happened here, perhaps started at the engine first.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390416
10/20/17 07:04 PM
10/20/17 07:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Take a good look at the rear gear....
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390417
10/20/17 07:04 PM
10/20/17 07:04 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
i had that happen before,typical 727
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390421
10/20/17 07:07 PM
10/20/17 07:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yes.... but was it because it was built like a "typical" 727.
Re: 727 explosion at Milan last night.... [Re: J_BODY] #2390431
10/20/17 07:21 PM
10/20/17 07:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
OUCH!!!!!!!!! That's gonna leave a mark
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390445
10/20/17 07:37 PM
10/20/17 07:37 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Perfect illustration showing why not to run brake lines across the firewall
Witnessed a 727 trans explosion in an early '70s Newport at a demo derby. The blast bent the brake pedal at a 45 degree angle, and the steel bar had to be at least a 1/4" thick. The floor pan was a sight to see too. The driver actually walked away after 15 minutes on the ground holding his ankle.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390446
10/20/17 07:38 PM
10/20/17 07:38 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm happy he's okay. Seeing these photos makes me feel good about the $600+ I spent on a steel drum.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390450
10/20/17 07:41 PM
10/20/17 07:41 PM
P
Porter67 Offline
Porter67  Offline
P
Could the fluid vapors in the trans blow?
Im thinking im gonna keep my crt trans now and probably throw the blanket back on it just for good measure.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2390458
10/20/17 07:57 PM
10/20/17 07:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A local racer recently lost a sprag which wiped out the case and rear support. Disassembly found other distressed parts. I gave him a list of the minimum parts I would replace but he won't spend the money.
Sometimes an incident like this is the only way to make believers out of skeptics.
