Modifing 73 Challenger Headlight Questions? #2390152
10/20/17 01:41 AM
10/20/17 01:41 AM
moparAL Offline OP
moparAL  Offline OP
I have a 73 Challenger. Is it possible to make my Challenger use 2 hi/lo headlights (not 4) like a Cuda or Barracuda? I can modify the area behind the other 2 headlights to be fresh air intakes, like the new Dodge Demon. Your thoughts on how to do the modifcations. Thanks everybody.
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390161
10/20/17 02:01 AM
10/20/17 02:01 AM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
2 headlight system uses larger diameter bulbs, so they won't fit the buckets. Guess you could swap buckets, but you would have to also do a lot of mods/custom fabrication to the headlight bezels too. I wouldn't do it...Plus there are the wiring mods.
When you work on Spaceships for a living, how bad can a workday be?
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390174
10/20/17 02:39 AM
10/20/17 02:39 AM
can you change the type of bulbs you have to achieve what you are after for different/improved lighting?
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390192
10/20/17 04:24 AM
10/20/17 04:24 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
This is a good question because I am wondering what the diameter difference is between the 1973 and the 2017? With the halo's and everything they look like they could be close???
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390216
10/20/17 10:33 AM
10/20/17 10:33 AM
moparAL Offline OP
moparAL  Offline OP
I like the idea of a small replacable bulb, more light per bulb, I would wire it with a relay(more efficent & brighter). Just mounting it with the ability of aiming it are the major concerns!
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390571
10/20/17 11:13 PM
10/20/17 11:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes you can use to high bulbs swapped into the low location. You need to notch the low beam buckets to fit the locating nubs in the high beam bulbs. Then splice the high be circuits to those bulbs. Easy.
Doug
Re: Modifing 73 Challenger Headlight Questions? [Re: dvw] #2390579
10/20/17 11:23 PM
10/20/17 11:23 PM
^^^ Ding ding ding I (do) believe we have a winna.
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390584
10/20/17 11:30 PM
10/20/17 11:30 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
You're all missing his main point here. He wants to use the bright areas as air intakes like on the new Demon.
Re: Modifing 73 Challenger Headlight Questions? [Re: Sunroofcuda] #2390590
10/20/17 11:40 PM
10/20/17 11:40 PM
You're right, I (re) read it & saw the fresh air intake inquiry
Re: Modifing 73 Challenger Headlight Questions? [Re: moparAL] #2390621
10/21/17 12:37 AM
10/21/17 12:37 AM
CA
crackedback Online content
crackedback  Online Content
CA
You may want to test and see if the single smaller 5.75" diameter light puts out enough light and in a pattern you like before going full bore.
If you plan on running a hign beam bulb in the low location, it requires no changes to the wiring system, as the low socket has a wire for both high and low beam modes.
Wiring in a relay system to power them is a good idea. Plenty of voltage drop in the OEM harness/system.
