Re: 727 explosion at Milan last night....
[Re: dustergirl340]
#2391020
10/22/17 12:09 AM
10/22/17 12:09 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Ok who are the suppliers for the drum and valve bodies needed, I did a quick search and came back with zip.
Have a great day Iowan
"obsolete is neat"
[Re: Tempest]
#2391032
10/22/17 12:46 AM
10/22/17 12:46 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Asking this question again for clarification. If one does not have an aftermarket drum and LBA, will launching car in 2nd avoid (for the most part) this issue? I suppose it would, but you generally need first gear in drag racing. Since it’s generally when you freewheel the trans in 1st without the band applied that the drum is at risk, Most do their burnout starting in second to avoid the issue.
[Re: Leigh]
#2391033
10/22/17 12:52 AM
10/22/17 12:52 AM
Iowan
Lost in Time
Ascertain the performance required, select the trans and get out the credit card. There is no free lunch. They all have issues and their associated costs. I've been running the same trans since 1988, all Turbo Action parts including the valve body. No rebuilds just maintenance, 1.40 60ft times no trans brake. I'm just looking for the suppliers for the parts.
"obsolete is neat"
[Re: Iowan]
#2391040
10/22/17 01:10 AM
10/22/17 01:10 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I bought my 727 from CRT. Building the trans is one of the few things I don't do on my cars . He sells the parts as well. http://coperacingtrans.com/ Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Iowan]
#2391044
10/22/17 01:43 AM
10/22/17 01:43 AM
Posts: 20,175 Park Forest, IL
slantzilla
Park Forest, IL
Ascertain the performance required, select the trans and get out the credit card. There is no free lunch. They all have issues and their associated costs. I've been running the same trans since 1988, all Turbo Action parts including the valve body. No rebuilds just maintenance, 1.40 60ft times no trans brake. I'm just looking for the suppliers for the parts. Call Keith Long/ 727specialists. 219/718-3542
[Re: d7cook]
#2391065
10/22/17 03:04 AM
10/22/17 03:04 AM
Posts: 201 PA
Scully
PA
It's kind of funny a year ago I posted the question about using a turbo 400 behind my big block and was told to stick with the 727 even by Monty. GM Trannies explode too IF they are not built right or are abused. Any trans can be a time bomb if abused with the wrong parts. Th400 main problem is tossing into nuetral across the stripe. Unless you have a valve body deigned to do it. 123n. I currently run one. Easy to build. BOP versions are cheap and plentiful. Personally I have always hated the 2-3 shift on 727's and tweaking the band. The 2-3 shift is all about timing to avoid overlap and you can find the sweet spot by understanding the front clutch clearance, springs and the kickdown lever ratio and adjustment. The 4.2 lever is the best all around IMO, the rest comes from experience but a good 727 trans guy should know this.
[Re: Iowan]
#2391071
10/22/17 04:02 AM
10/22/17 04:02 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
CRT, Pro Trans, ATI,T/A,A&A and a lot of others Three choices on the front drum beside stock, aluminum, alunimum with a steel liner and all steel
[Re: mopar dave]
#2391234
10/22/17 02:24 PM
10/22/17 02:24 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Keith knows a thing or two about transmissions. Bought my aluminum drum from him as well as some other parts. I like Copes rmv bodies with rear band apply. I wonder about these new vb'd lba and if they were ever test on a bench or dyno to verify there correct function.[delay in shift 1 to 2 correctly.cause effect]
[Re: dvw]
#2391264
10/22/17 03:04 PM
10/22/17 03:04 PM
Cab_Burge
[Re: Porter67]
#2391289
10/22/17 03:44 PM
10/22/17 03:44 PM
Clanton
northern,Ohio,USA
Are you meaning copes brand or that type VB overall? Any brand,The racers seem to be the test bed for a new product to work out the bug most of the time.
[Re: mopar dave]
#2391290
10/22/17 03:45 PM
10/22/17 03:45 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
so why would anyone pay more for the super sprag if they break too? save your money and just install a bolt in stock type then and use an aftermarket drum. That's what I did.
[Re: Scully]
#2391295
10/22/17 03:58 PM
10/22/17 03:58 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
It's kind of funny a year ago I posted the question about using a turbo 400 behind my big block and was told to stick with the 727 even by Monty. GM Trannies explode too IF they are not built right or are abused. Any trans can be a time bomb if abused with the wrong parts. Th400 main problem is tossing into nuetral across the stripe. Unless you have a valve body deigned to do it. 123n. I currently run one. Easy to build. BOP versions are cheap and plentiful. Personally I have always hated the 2-3 shift on 727's and tweaking the band. The 2-3 shift is all about timing to avoid overlap and you can find the sweet spot by understanding the front clutch clearance, springs and the kickdown lever ratio and adjustment. The 4.2 lever is the best all around IMO, the rest comes from experience but a good 727 trans guy should know this. Ironically one way to make a th400 bullet prof is to go sprag less which I think griner developed the vb for but...... The 2-3 shift becomes about timing to avoid overlap.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: justinp61]
#2391297
10/22/17 04:00 PM
10/22/17 04:00 PM
Posts: 20,170 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did anyone ever check to see if ATI makes a 727 aftermarket case. My ATI Case is very heavy duty and comes with a steel safety liner that slides down into the pump
[Re: Clanton]
#2391301
10/22/17 04:04 PM
10/22/17 04:04 PM
Porter67
Ive an aa or aaa? I think cope uses his own now? And ive never noticed a delay at the track or street when hooked, if im horsing around and blow the drag radials off I can hear the 1-2 shift in the motor but its not enough to make the tach needle drop, by then im already in 2nd at 7200, about a second and a half but I always run it out when I do and it gently hooks, I never let off abruptly. Do the data loggers show the delay? I wonder about these new vb'd lba and if they were ever test on a bench or dyno to verify there correct function.[delay in shift 1 to 2 correctly.cause effect]
