Re: Best method to jig up rear to weld spring pads?
[Re: 340SHORTY]
#238991
02/28/09 06:32 PM
02/28/09 06:32 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
the second part of your question is your answer....
That's the way I did them on the last car I had leaf springs on.
[Re: 340SHORTY]
#238992
02/28/09 06:41 PM
02/28/09 06:41 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I am just in the process of doing the same as you, i've also made new front spring hangers. I have tack welded mine on with a small amount of nose down, i'm going to fit the wheels then drop the car onto the deck check the pinion angle and if it's not right i'll raise it up drop the wheels off, break the tacks, adjust it,weld them solid and put it back together. What width is yours, mine is 52", so i will need new wheels as my 8-3/4 was stock width, i used c.lines with a 7-1/4 b.s Mike Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
